System images upgrade failed
I am running VyOS 1.5-rolling-202407280023 , I was trying to upgrade the image with current runing configurations . I tried 1.5-rolling-202409240007 / 1.5-rolling-202409020006 / 1.5-rolling-202408280022 but these new images both hangs after boot, the wan interface(pppoe) is not up and LAN ip can ping , but I was not able to connect my vyos server via ssh , here is the systmed logs :
Sep 24 12:06:04 vyos python3[691]: Report time:      2024-09-24 12:06:04
Sep 24 12:06:04 vyos vyos-configd[691]: VyOS had an issue completing a command.
Sep 24 12:06:04 vyos vyos-configd[691]: We are sorry that you encountered a problem while using VyOS.
Sep 24 12:06:04 vyos vyos-configd[691]: There are a few things you can do to help us (and yourself):
Sep 24 12:06:04 vyos vyos-configd[691]: - Contact us using the online help desk if you have a subscription:
Sep 24 12:06:04 vyos vyos-configd[691]:   https://support.vyos.io/
Sep 24 12:06:04 vyos vyos-configd[691]: - Make sure you are running the latest version of VyOS available at:
Sep 24 12:06:04 vyos vyos-configd[691]:   https://vyos.net/get/
Sep 24 12:06:04 vyos vyos-configd[691]: - Consult the community forum to see how to handle this issue:
Sep 24 12:06:04 vyos vyos-configd[691]:   https://forum.vyos.io
Sep 24 12:06:04 vyos vyos-configd[691]: - Join us on Slack where our users exchange help and advice:
Sep 24 12:06:04 vyos vyos-configd[691]:   https://vyos.slack.com
Sep 24 12:06:04 vyos vyos-configd[691]: When reporting problems, please include as much information as possible:
Sep 24 12:06:04 vyos vyos-configd[691]: - do not obfuscate any data (feel free to contact us privately if your
Sep 24 12:06:04 vyos vyos-configd[691]:   business policy requires it)
Sep 24 12:06:04 vyos vyos-configd[691]: - and include all the information presented below
Sep 24 12:06:04 vyos vyos-configd[691]: Report time:      2024-09-24 12:06:04
Sep 24 12:06:04 vyos vyos-configd[691]: Image version:    VyOS 1.5-rolling-202409240007
Sep 24 12:06:04 vyos vyos-configd[691]: Release train:    current
Sep 24 12:06:04 vyos vyos-configd[691]: Built by:         autobuild@vyos.net
Sep 24 12:06:04 vyos vyos-configd[691]: Built on:         Tue 24 Sep 2024 00:07 UTC
Sep 24 12:06:04 vyos vyos-configd[691]: Build UUID:       113ceb9f-8232-4b82-b7c5-a2fc6a70260d
Sep 24 12:06:04 vyos vyos-configd[691]: Build commit ID:  fa50a5073b6d3f
Sep 24 12:06:04 vyos vyos-configd[691]: Architecture:     x86_64
Sep 24 12:06:04 vyos vyos-configd[691]: Boot via:         installed image
Sep 24 12:06:04 vyos vyos-configd[691]: System type:      bare metal
Sep 24 12:06:04 vyos vyos-configd[691]: Hardware vendor:  CncTion
Sep 24 12:06:04 vyos vyos-configd[691]: Hardware model:   N4100-4L
Sep 24 12:06:04 vyos vyos-configd[691]: Hardware S/N:     Default string
Sep 24 12:06:04 vyos vyos-configd[691]: Hardware UUID:    03000200-0400-0500-0006-000700080009
Sep 24 12:06:04 vyos vyos-configd[691]: Traceback (most recent call last):
Sep 24 12:06:04 vyos vyos-configd[691]:   File "/usr/libexec/vyos/services/vyos-configd", line 324, in <module>
Sep 24 12:06:04 vyos vyos-configd[691]:     message = json.loads(msg)
Sep 24 12:06:04 vyos vyos-configd[691]:               ^^^^^^^^^^^^^^^
Sep 24 12:06:04 vyos vyos-configd[691]:   File "/usr/lib/python3.11/json/__init__.py", line 346, in loads
Sep 24 12:06:04 vyos vyos-configd[691]:     return _default_decoder.decode(s)
Sep 24 12:06:04 vyos vyos-configd[691]:            ^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 12:06:04 vyos vyos-configd[691]:   File "/usr/lib/python3.11/json/decoder.py", line 337, in decode
Sep 24 12:06:04 vyos vyos-configd[691]:     obj, end = self.raw_decode(s, idx=_w(s, 0).end())
Sep 24 12:06:04 vyos vyos-configd[691]:                ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Sep 24 12:06:04 vyos vyos-configd[691]:   File "/usr/lib/python3.11/json/decoder.py", line 355, in raw_decode
Sep 24 12:06:04 vyos vyos-configd[691]:     raise JSONDecodeError("Expecting value", s, err.value) from None
Sep 24 12:06:04 vyos vyos-configd[691]: json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Sep 24 12:06:04 vyos vyos-configd[691]: noteworthy:
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'utmpdump /run/utmp'
Sep 24 12:06:04 vyos vyos-configd[691]: returned (out):
Sep 24 12:06:04 vyos python3[691]: Image version:    VyOS 1.5-rolling-202409240007
Sep 24 12:06:04 vyos vyos-configd[691]: [2] [00000] [~~  ] [reboot  ] [~           ] [6.6.51-vyos         ] [0.0.0.0        ] [2024-09-24T04:05:02,779162+00:00]
Sep 24 12:06:04 vyos vyos-configd[691]: [1] [00051] [~~  ] [runlevel] [~           ] [6.6.51-vyos         ] [0.0.0.0        ] [2024-09-24T04:05:07,905419+00:00]
Sep 24 12:06:04 vyos vyos-configd[691]: [5] [00965] [tty1] [        ] [tty1        ] [                    ] [0.0.0.0        ] [2024-09-24T04:05:07,919762+00:00]
Sep 24 12:06:04 vyos vyos-configd[691]: returned (err):
Sep 24 12:06:04 vyos vyos-configd[691]: Utmp dump of /run/utmp
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'nft --check delete element inet vrf_zones ct_iface_map { "lo" }'
Sep 24 12:06:04 vyos vyos-configd[691]: Error: Could not process rule: No such file or directory
Sep 24 12:06:04 vyos vyos-configd[691]: delete element inet vrf_zones ct_iface_map { lo }
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'ip link show dev br1'
Sep 24 12:06:04 vyos vyos-configd[691]: Device "br1" does not exist.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'nft --check delete element inet vrf_zones ct_iface_map { "br1" }'
Sep 24 12:06:04 vyos vyos-configd[691]: delete element inet vrf_zones ct_iface_map { br1 }
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'ip link show dev br0'
Sep 24 12:06:04 vyos vyos-configd[691]: Device "br0" does not exist.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'nft --check delete element inet vrf_zones ct_iface_map { "br0" }'
Sep 24 12:06:04 vyos vyos-configd[691]: delete element inet vrf_zones ct_iface_map { br0 }
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'ip link show dev bond1'
Sep 24 12:06:04 vyos vyos-configd[691]: Device "bond1" does not exist.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'ip link show dev bond0'
Sep 24 12:06:04 vyos vyos-configd[691]: Device "bond0" does not exist.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'ip link show dev wg0'
Sep 24 12:06:04 vyos vyos-configd[691]: Device "wg0" does not exist.
Sep 24 12:06:04 vyos python3[691]: Release train:    current
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'nft --check delete element inet vrf_zones ct_iface_map { "wg0" }'
Sep 24 12:06:04 vyos vyos-configd[691]: delete element inet vrf_zones ct_iface_map { wg0 }
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'pam-auth-update --disable radius-mandatory radius-optional'
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: unable to initialize frontend: Dialog
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: (TERM is not set, so the dialog frontend is not usable.)
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: falling back to frontend: Readline
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: unable to initialize frontend: Readline
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: (This frontend requires a controlling tty.)
Sep 24 12:06:04 vyos vyos-configd[691]: debconf: falling back to frontend: Teletype
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'pam-auth-update --disable tacplus-mandatory tacplus-optional'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'pam-auth-update --disable mfa-google-authenticator'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'nft --check delete element inet vrf_zones ct_iface_map { "pod-Net-Podman" }'
Sep 24 12:06:04 vyos python3[691]: Built by:         autobuild@vyos.net
Sep 24 12:06:04 vyos vyos-configd[691]: delete element inet vrf_zones ct_iface_map { pod-Net-Podman }
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev lo parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: Error: Cannot find specified qdisc on specified device.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev lo root'
Sep 24 12:06:04 vyos vyos-configd[691]: Error: Cannot delete qdisc with handle of zero.
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth0 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth0 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth1 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth1 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth2 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth2 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth3 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev eth3 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev pim6reg parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev pim6reg root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev br1 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev br1 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev br0 parent ffff:'
Sep 24 12:06:04 vyos python3[691]: Built on:         Tue 24 Sep 2024 00:07 UTC
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev br0 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev bond1 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev bond1 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev bond0 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev bond0 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev wg0 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev wg0 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev pod-Net-Podman parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev pod-Net-Podman root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth0 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth0 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth1 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth1 root'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth2 parent ffff:'
Sep 24 12:06:04 vyos vyos-configd[691]: cmd 'tc qdisc del dev veth2 root'
Hi
can you also share configuration please
thanks
Hi Syncer,
Here is my configurations:
set container name cloudflared host-name xxxxxx
set container name cloudflared image 'cloudflare/cloudflared:latest'
set container name homarr host-name xxxxxx
set container name homarr image 'ghcr.io/ajnart/homarr:latest'
set container name homarr network Net-Podman address 'xxx.xxx.0.10'
set container name homarr port homarr_web destination '7575'
set container name homarr port homarr_web listen-address 'xxx.xxx.0.254'
set container name homarr port homarr_web source '80'
set container name homarr restart 'on-failure'
set container name homarr volume homarr_configs destination '/app/data/configs'
set container name homarr volume homarr_configs source '/config/container/homarr/configs'
set container name homarr volume homarr_data destination '/data'
set container name homarr volume homarr_data source '/config/container/homarr/data'
set container name homarr volume homarr_icons destination '/app/public/icons'
set container name homarr volume homarr_icons source '/config/container/homarr/icons'
set container name mosdns allow-host-networks
set container name mosdns capability 'net-bind-service'
set container name mosdns host-name xxxxxx
set container name mosdns image 'irinesistiana/mosdns'
set container name mosdns volume mosdns_data destination '/etc/mosdns'
set container name mosdns volume mosdns_data source '/config/container/mosdns/'
set container name openspeedtest environment CHANGE_CONTAINER_PORTS value 'True'
set container name openspeedtest environment HTTP_PORT value '4000'
set container name openspeedtest host-name xxxxxx
set container name openspeedtest image 'openspeedtest/latest:latest'
set container name openspeedtest network Net-Podman address 'xxx.xxx.0.20'
set container name openspeedtest port openspeedtest_web destination '4000'
set container name openspeedtest port openspeedtest_web listen-address 'xxx.xxx.0.254'
set container name openspeedtest port openspeedtest_web source '2000'
set container name openspeedtest restart 'on-failure'
set container name tailscale allow-host-networks
set container name tailscale capability 'net-admin'
set container name tailscale capability 'net-raw'
set container name tailscale device devtun destination '/dev/net/tun'
set container name tailscale device devtun source '/dev/net/tun'
set container name tailscale environment TS_AUTHKEY value 'xxxxxxxxxxxxxxxx'
set container name tailscale environment TS_EXTRA_ARGS value '--advertise-exit-node'
set container name tailscale environment TS_HOSTNAME value 'VYOS'
set container name tailscale environment TS_ROUTES value 'xxx.xxx.0.1/32,xxx.xxx.0.254/32'
set container name tailscale environment TS_STATE_DIR value '/var/lib/tailscale'
set container name tailscale host-name xxxxxx
set container name tailscale image 'tailscale/tailscale:latest'
set container name tailscale memory '0'
set container name tailscale restart 'on-failure'
set container name tailscale shared-memory '0'
set container name tailscale volume tailscale_data destination '/var/lib/tailscale'
set container name tailscale volume tailscale_data source '/config/container/tailscale'
set container name uptime-kuma capability 'net-raw'
set container name uptime-kuma host-name xxxxxx
set container name uptime-kuma image 'louislam/uptime-kuma:latest'
set container name uptime-kuma network Net-Podman address 'xxx.xxx.0.30'
set container name uptime-kuma port uptimekuma_web destination '3001'
set container name uptime-kuma port uptimekuma_web listen-address 'xxx.xxx.0.254'
set container name uptime-kuma port uptimekuma_web source '3000'
set container name uptime-kuma restart 'always'
set container name uptime-kuma volume uptime-kuma destination '/app/data'
set container name uptime-kuma volume uptime-kuma source '/config/container/uptime-kuma'
set container name v2ray allow-host-networks
set container name v2ray capability 'net-admin'
set container name v2ray command 'run  --confdir /etc/v2ray/'
set container name v2ray host-name xxxxxx
set container name v2ray image 'v2fly/v2fly-core:latest'
set container name v2ray volume v2ray_data destination '/etc/v2ray/'
set container name v2ray volume v2ray_data source '/config/container/v2ray/'
set container network Net-Podman prefix 'xxx.xxx.0.0/24'
set container registry docker.io
set container registry ghcr.io
set container registry public.ecr.aws
set container registry quay.io
set firewall global-options all-ping 'enable'
set firewall global-options state-policy established action 'accept'
set firewall global-options state-policy invalid action 'drop'
set firewall global-options state-policy invalid log
set firewall global-options state-policy related action 'accept'
set firewall global-options syn-cookies 'enable'
set firewall group address-group OpenDns address 'xxx.xxx.220.220'
set firewall group address-group OpenDns address 'xxx.xxx.222.222'
set firewall group address-group OpenDns address 'xxx.xxx.220.222'
set firewall group address-group OpenDns address 'xxx.xxx.222.220'
set firewall group address-group OpenDns address 'xxx.xxx.222.123'
set firewall group address-group OpenDns address 'xxx.xxx.220.123'
set firewall group address-group OpenDns address 'xxx.xxx.222.2'
set firewall group address-group OpenDns address 'xxx.xxx.220.2'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:35::35'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:53::53'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:35::123'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:53::123'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:ccc::2'
set firewall group ipv6-address-group OpenDNS-IPv6 address 'xxxx:xxxx:ccd::2'
set firewall ipv4 name LAN_to_LOCAL default-action 'accept'
set firewall ipv4 name LAN_to_PODMAN default-action 'accept'
set firewall ipv4 name LAN_to_WAN default-action 'accept'
set firewall ipv4 name LAN_to_WAN rule 10 action 'drop'
set firewall ipv4 name LAN_to_WAN rule 10 destination group address-group 'OpenDns'
set firewall ipv4 name LAN_to_WAN rule 10 log
set firewall ipv4 name LAN_to_WAN rule 10 protocol 'all'
set firewall ipv4 name LAN_to_WAN rule 20 action 'return'
set firewall ipv4 name LAN_to_WAN rule 20 description 'ipv4 stateful from LAN to WAN'
set firewall ipv4 name LAN_to_WAN rule 20 state 'established'
set firewall ipv4 name LAN_to_WAN rule 20 state 'related'
set firewall ipv4 name LAN_to_WAN rule 20 state 'new'
set firewall ipv4 name LAN_to_WAN rule 20 state 'invalid'
set firewall ipv4 name LAN_to_WG default-action 'accept'
set firewall ipv4 name LOCAL_to_LAN default-action 'accept'
set firewall ipv4 name LOCAL_to_PODMAN default-action 'accept'
set firewall ipv4 name LOCAL_to_WAN default-action 'accept'
set firewall ipv4 name LOCAL_to_WG default-action 'accept'
set firewall ipv4 name LOCAL_to_WG description 'Allow Vyos to HK WG server'
set firewall ipv4 name PODMAN_to_LAN default-action 'accept'
set firewall ipv4 name PODMAN_to_LOCAL default-action 'accept'
set firewall ipv4 name PODMAN_to_WAN default-action 'accept'
set firewall ipv4 name PODMAN_to_WAN rule 20 action 'return'
set firewall ipv4 name PODMAN_to_WAN rule 20 description 'ipv4 stateful from PODMAN to WAN'
set firewall ipv4 name PODMAN_to_WAN rule 20 state 'established'
set firewall ipv4 name PODMAN_to_WAN rule 20 state 'related'
set firewall ipv4 name PODMAN_to_WAN rule 20 state 'new'
set firewall ipv4 name PODMAN_to_WAN rule 20 state 'invalid'
set firewall ipv4 name PODMAN_to_WG default-action 'accept'
set firewall ipv4 name WAN_to_LAN default-action 'drop'
set firewall ipv4 name WAN_to_LAN default-log
set firewall ipv4 name WAN_to_LOCAL default-action 'drop'
set firewall ipv4 name WAN_to_LOCAL default-log
set firewall ipv4 name WAN_to_PODMAN default-action 'drop'
set firewall ipv4 name WAN_to_PODMAN default-log
set firewall ipv4 name WG_to_LOCAL default-action 'accept'
set firewall ipv6 name LAN_to_LOCAL-ipv6 default-action 'accept'
set firewall ipv6 name LAN_to_WAN-ipv6 default-action 'accept'
set firewall ipv6 name LAN_to_WAN-ipv6 description 'ipv6 stateful from LAN to WAN'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 10 action 'drop'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 10 destination group address-group 'OpenDNS-IPv6'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 10 log
set firewall ipv6 name LAN_to_WAN-ipv6 rule 10 protocol 'all'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 20 action 'return'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 20 state 'established'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 20 state 'new'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 20 state 'related'
set firewall ipv6 name LAN_to_WAN-ipv6 rule 20 state 'invalid'
set firewall ipv6 name LOCAL_to_LAN-ipv6 default-action 'accept'
set firewall ipv6 name LOCAL_to_WAN-ipv6 default-action 'accept'
set firewall ipv6 name PODMAN_to_WAN-ipv6 default-action 'accept'
set firewall ipv6 name PODMAN_to_WAN-ipv6 rule 20 action 'return'
set firewall ipv6 name PODMAN_to_WAN-ipv6 rule 20 state 'established'
set firewall ipv6 name PODMAN_to_WAN-ipv6 rule 20 state 'new'
set firewall ipv6 name PODMAN_to_WAN-ipv6 rule 20 state 'related'
set firewall ipv6 name PODMAN_to_WAN-ipv6 rule 20 state 'invalid'
set firewall ipv6 name WAN_to_LAN-ipv6 default-action 'drop'
set firewall ipv6 name WAN_to_LAN-ipv6 default-log
set firewall ipv6 name WAN_to_LOCAL-ipv6 default-action 'drop'
set firewall ipv6 name WAN_to_LOCAL-ipv6 default-log
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 10 action 'drop'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 10 icmpv6 type-name 'echo-request'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 10 protocol 'ipv6-icmp'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 20 action 'accept'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 20 protocol 'ipv6-icmp'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 30 action 'accept'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 30 destination port '546'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 30 protocol 'udp'
set firewall ipv6 name WAN_to_LOCAL-ipv6 rule 30 source port '547'
set firewall zone LAN default-action 'drop'
set firewall zone LAN from LOCAL firewall ipv6-name 'LOCAL_to_LAN-ipv6'
set firewall zone LAN from LOCAL firewall name 'LOCAL_to_LAN'
set firewall zone LAN from PODMAN firewall name 'PODMAN_to_LAN'
set firewall zone LAN from WAN firewall ipv6-name 'WAN_to_LAN-ipv6'
set firewall zone LAN from WAN firewall name 'WAN_to_LAN'
set firewall zone LAN interface 'br1'
set firewall zone LOCAL default-action 'drop'
set firewall zone LOCAL from LAN firewall ipv6-name 'LAN_to_LOCAL-ipv6'
set firewall zone LOCAL from LAN firewall name 'LAN_to_LOCAL'
set firewall zone LOCAL from PODMAN firewall name 'PODMAN_to_LOCAL'
set firewall zone LOCAL from WAN firewall ipv6-name 'WAN_to_LOCAL-ipv6'
set firewall zone LOCAL from WAN firewall name 'WAN_to_LOCAL'
set firewall zone LOCAL from WG firewall name 'WG_to_LOCAL'
set firewall zone LOCAL local-zone
set firewall zone PODMAN default-action 'drop'
set firewall zone PODMAN from LAN firewall name 'LAN_to_PODMAN'
set firewall zone PODMAN from LOCAL firewall name 'LOCAL_to_PODMAN'
set firewall zone PODMAN from WAN firewall name 'WAN_to_PODMAN'
set firewall zone PODMAN interface 'pod-Net-Podman'
set firewall zone WAN default-action 'drop'
set firewall zone WAN from LAN firewall ipv6-name 'LAN_to_WAN-ipv6'
set firewall zone WAN from LAN firewall name 'LAN_to_WAN'
set firewall zone WAN from LOCAL firewall ipv6-name 'LOCAL_to_WAN-ipv6'
set firewall zone WAN from LOCAL firewall name 'LOCAL_to_WAN'
set firewall zone WAN from PODMAN firewall ipv6-name 'PODMAN_to_WAN-ipv6'
set firewall zone WAN from PODMAN firewall name 'PODMAN_to_WAN'
set firewall zone WAN interface 'br0'
set firewall zone WAN interface 'pppoe0'
set firewall zone WG default-action 'drop'
set firewall zone WG from LAN firewall name 'LAN_to_WG'
set firewall zone WG from LOCAL firewall name 'LOCAL_to_WG'
set firewall zone WG from PODMAN firewall name 'PODMAN_to_WG'
set firewall zone WG interface 'wg0'
set firewall zone WG interface 'wg1'
set interfaces bonding bond0 description 'Bond Interface WAN'
set interfaces bonding bond0 member interface 'eth0'
set interfaces bonding bond0 member interface 'eth1'
set interfaces bonding bond1 description 'Bond Interface LAN'
set interfaces bonding bond1 member interface 'eth2'
set interfaces bonding bond1 member interface 'eth3'
set interfaces bridge br0 address 'xxx.xxx.1.254/32'
set interfaces bridge br0 description 'WAN bridge'
set interfaces bridge br0 member interface bond0
set interfaces bridge br0 stp
set interfaces bridge br1 address 'xxx.xxx.0.1/24'
set interfaces bridge br1 address 'xxx.xxx.0.254/32'
set interfaces bridge br1 description 'LAN bridge'
set interfaces bridge br1 member interface bond1
set interfaces bridge br1 stp
set interfaces ethernet eth0 hw-id 'xx:xx:xx:xx:xx:6a'
set interfaces ethernet eth0 offload rfs
set interfaces ethernet eth0 offload rps
set interfaces ethernet eth0 ring-buffer rx '4096'
set interfaces ethernet eth0 ring-buffer tx '4096'
set interfaces ethernet eth1 hw-id 'xx:xx:xx:xx:xx:6b'
set interfaces ethernet eth1 offload rfs
set interfaces ethernet eth1 offload rps
set interfaces ethernet eth1 ring-buffer rx '4096'
set interfaces ethernet eth1 ring-buffer tx '4096'
set interfaces ethernet eth2 hw-id 'xx:xx:xx:xx:xx:6c'
set interfaces ethernet eth2 offload gro
set interfaces ethernet eth2 offload gso
set interfaces ethernet eth2 offload rfs
set interfaces ethernet eth2 offload rps
set interfaces ethernet eth2 offload sg
set interfaces ethernet eth2 offload tso
set interfaces ethernet eth2 ring-buffer rx '4096'
set interfaces ethernet eth2 ring-buffer tx '4096'
set interfaces ethernet eth3 hw-id 'xx:xx:xx:xx:xx:6d'
set interfaces ethernet eth3 offload gro
set interfaces ethernet eth3 offload gso
set interfaces ethernet eth3 offload rfs
set interfaces ethernet eth3 offload rps
set interfaces ethernet eth3 offload sg
set interfaces ethernet eth3 offload tso
set interfaces ethernet eth3 ring-buffer rx '4096'
set interfaces ethernet eth3 ring-buffer tx '4096'
set interfaces loopback lo
set interfaces pppoe pppoe0 authentication password xxxxxx
set interfaces pppoe pppoe0 authentication username xxxxxx
set interfaces pppoe pppoe0 dhcpv6-options pd 0 interface br1 address '1'
set interfaces pppoe pppoe0 dhcpv6-options pd 0 interface br1 sla-id '0'
set interfaces pppoe pppoe0 dhcpv6-options pd 0 length '60'
set interfaces pppoe pppoe0 ip adjust-mss 'clamp-mss-to-pmtu'
set interfaces pppoe pppoe0 ipv6 address autoconf
set interfaces pppoe pppoe0 ipv6 adjust-mss 'clamp-mss-to-pmtu'
set interfaces pppoe pppoe0 mtu '1480'
set interfaces pppoe pppoe0 source-interface 'br0'
set interfaces wireguard wg0 address 'xxx.xxx.0.1/24'
set interfaces wireguard wg0 description 'OSPF over WG HK Peer'
set interfaces wireguard wg0 ip adjust-mss 'clamp-mss-to-pmtu'
set interfaces wireguard wg0 peer to_HK address 'xxx.xxx.0.254'
set interfaces wireguard wg0 peer to_HK allowed-ips 'xxx.xxx.0.0/0'
set interfaces wireguard wg0 peer to_HK allowed-ips 'xxx.xxx.0.0/24'
set interfaces wireguard wg0 peer to_HK persistent-keepalive '5'
set interfaces wireguard wg0 peer to_HK port '5000'
set interfaces wireguard wg0 peer to_HK public-key 'xxxxxx'
set interfaces wireguard wg0 private-key xxxxxx
set nat source rule 10 description 'OSPF over Wireguard SNAT'
set nat source rule 10 outbound-interface name 'wg0'
set nat source rule 10 translation address 'masquerade'
set nat source rule 20 description 'LAN to ZTE ONU SNAT'
set nat source rule 20 outbound-interface name 'br0'
set nat source rule 20 translation address 'masquerade'
set policy
set protocols bfd peer xxxxx.tld source address 'xxx.xxx.0.1'
set protocols ospf area xxx.xxx.0.0 network 'xxx.xxx.0.0/24'
set protocols ospf auto-cost reference-bandwidth '100'
set protocols ospf interface wg0 bfd
set protocols ospf interface wg0 network 'non-broadcast'
set protocols ospf interface wg0 priority '1'
set protocols ospf interface wg0 retransmit-interval '5'
set protocols ospf interface wg0 transmit-delay '1'
set protocols ospf log-adjacency-changes detail
set protocols ospf neighbor xxx.xxx.0.254
set protocols ospf parameters router-id 'xxx.xxx.0.1'
set protocols ospf redistribute connected
set protocols static route xxx.xxx.1.0/24 description 'LAN to ZTE ONU'
set protocols static route xxx.xxx.1.0/24 interface br0
set qos interface br0 egress 'Qos_Cake_Lan'
set qos policy cake Qos_Cake_Lan bandwidth '1gbit'
set qos policy cake Qos_Cake_Lan description 'Qos For Lan interface br1'
set qos policy cake Qos_Cake_Lan flow-isolation dual-src-host
set qos policy cake Qos_Cake_Lan rtt '100'
set service dhcp-server dynamic-dns-update
set service dhcp-server hostfile-update
set service dhcp-server listen-interface 'br1'
set service dhcp-server shared-network-name xxxxxx authoritative
set service dhcp-server shared-network-name xxxxxx option ntp-server 'xxx.xxx.0.1'
set service dhcp-server shared-network-name xxxxxx option time-zone 'Asia/Shanghai'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 lease '86400'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 option default-router 'xxx.xxx.0.1'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 option domain-name xxxxxx
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 option domain-search xxxxxx
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 option name-server 'xxx.xxx.0.1'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 range 100 start 'xxx.xxx.0.100'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 range 100 stop 'xxx.xxx.0.200'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.21'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:0b'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.20'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:79'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.23'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:f3'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.22'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:6a'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.26'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:b6'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.28'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:02'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.2'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:42'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.150'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:80'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx ip-address 'xxx.xxx.0.27'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 static-mapping xxxxxx mac 'xx:xx:xx:xx:xx:6c'
set service dhcp-server shared-network-name xxxxxx subnet xxx.xxx.0.0/24 subnet-id '1'
set service dns dynamic interval '300'
set service dns dynamic name cloudflare-ipv4 address web url xxxxxx
set service dns dynamic name cloudflare-ipv4 expiry-time '300'
set service dns dynamic name cloudflare-ipv4 host-name xxxxxx
set service dns dynamic name cloudflare-ipv4 ip-version 'ipv4'
set service dns dynamic name cloudflare-ipv4 password xxxxxx
set service dns dynamic name cloudflare-ipv4 protocol 'cloudflare'
set service dns dynamic name cloudflare-ipv4 username xxxxxx
set service dns dynamic name cloudflare-ipv4 zone 'xxxxxx'
set service dns dynamic name cloudflare-ipv6 address web url xxxxxx
set service dns dynamic name cloudflare-ipv6 expiry-time '300'
set service dns dynamic name cloudflare-ipv6 host-name xxxxxx
set service dns dynamic name cloudflare-ipv6 ip-version 'ipv6'
set service dns dynamic name cloudflare-ipv6 password xxxxxx
set service dns dynamic name cloudflare-ipv6 protocol 'cloudflare'
set service dns dynamic name cloudflare-ipv6 username xxxxxx
set service dns dynamic name cloudflare-ipv6 zone 'xxxxxx'
set service dns forwarding allow-from 'xxx.xxx.0.0/24'
set service dns forwarding authoritative-domain home.local records a ap address 'xxx.xxx.0.2'
set service dns forwarding authoritative-domain home.local records a vyos address 'xxx.xxx.0.1'
set service dns forwarding listen-address 'xxx.xxx.0.1'
set service dns forwarding listen-address '::1'
set service dns forwarding name-server xxx.xxx.0.254
set service ntp allow-client xxxxxx 'xxx.xxx.0.0/24'
set service ntp interface 'br1'
set service ntp listen-address 'xxx.xxx.0.1'
set service router-advert interface br1 link-mtu '1490'
set service router-advert interface br1 prefix ::/64 valid-lifetime '172800'
set service router-advert interface pppoe0
set service ssh access-control allow user xxxxxx
set service ssh listen-address 'xxx.xxx.0.1'
set service ssh port '22'
set system config-management commit-archive location xxxxxx
set system config-management commit-archive source-address 'xxx.xxx.0.1'
set system conntrack expect-table-size '10485760'
set system conntrack hash-size '10485760'
set system conntrack table-size '10485760'
set system host-name xxxxxx
set system ip arp table-size '32768'
set system ip multipath layer4-hashing
set system ipv6 multipath layer4-hashing
set system ipv6 neighbor table-size '32768'
set system name-server 'xxx.xxx.0.1'
set system option ctrl-alt-delete 'ignore'
set system option disable-usb-autosuspend
set system option kernel disable-mitigations
set system option kernel disable-power-saving
set system option performance 'throughput'
set system option reboot-on-panic
set system option root-partition-auto-resize
set system option startup-beep
set system option time-format '24-hour'
set system task-scheduler task image_rollback crontab-spec '*/5 * * * *'
set system task-scheduler task image_rollback executable path '/config/scripts/set_image.sh'
set system task-scheduler task update_mosdns_rule crontab-spec '10 4 * * *'
set system task-scheduler task update_mosdns_rule executable path '/config/container/mosdns/update.sh'
set system time-zone 'Asia/Shanghai'
set system update-check auto-check
set system update-check url xxxxxx
and here is the systemd logs during the boot, it’s a zip file, so please remove the .log extension at the end of filename,
system.journal.zip.log (1.3 MB)
decompress the zip file and view the log via command : journalctl --file=system.journal
Please let me know if you need anything else, thanks
