System sysctl error
Description:
On my VyOS system, I configured the following sysctl parameter to disable martian source logging:
set system sysctl parameter net.ipv4.conf.all.log_martians value '0'
After applying the configuration, the martian source log messages stopped as expected.
However, later the messages started appearing again. When I checked the live sysctl value, it had reverted to:
sysctl net.ipv4.conf.all.log_martians
net.ipv4.conf.all.log_martians = 1
But in the VyOS configuration, the parameter was still present and set to 0:
show configuration commands
conf
Configuration path: [system sysctl parameter net.ipv4.conf.all.log_martians value 0] already exists
Then I tried to delete it and commit:
del system sysctl parameter net.ipv4.conf.all.log_martians value '0'
commit
The commit failed with the following error:
[ system sysctl ]
  File "/usr/libexec/vyos/services/vyos-configd", line 157, in run_script
    script.apply(c)
  File "/usr/libexec/vyos/conf_mode/system_sysctl.py", line 62, in apply
    cmd(f'sysctl -f {config_file}')
  File "/usr/lib/python3/dist-packages/vyos/utils/process.py", line 209, in cmd
    raise OSError(code, feedback)
PermissionError: [Errno 1] failed to run command: None sysctl -f /run/sysctl/99-vyos-sysctl.conf
returned: net.core.netdev_budget = 600
net.core.netdev_budget_usecs = 8000
net.core.netdev_max_backlog = 10000
net.core.rmem_default = 16777216
net.core.rmem_max = 134217728
net.core.wmem_default = 16777216
net.core.wmem_max = 33554432
net.ipv4.neigh.default.gc_thresh1 = 1024
net.ipv4.neigh.default.gc_thresh2 = 4096
net.ipv4.neigh.default.gc_thresh3 = 8192
net.ipv4.tcp_rmem = 4096 87380 33554432
net.ipv4.tcp_wmem = 4096 65536 33554432
exit code: 1
[[system sysctl]] failed
Commit failed
Expected behavior:
The configuration should consistently keep net.ipv4.conf.all.log_martians = 0, or at least allow the setting to be removed cleanly without a commit failure.
Actual behavior:
The runtime sysctl value reverted to 1 even though the VyOS configuration still contained 0, and later removing the config caused commit to fail in system_sysctl.
Impact:
This causes unexpected martian logging to return, and the configuration cannot be safely cleaned up because the commit fails.
Version: VyOS 2026.04.01-0034-rolling
Additional information:
The issue started occurring after I applied the following configuration changes:
delete firewall ipv4 prerouting raw rule 5
delete nat source rule 100
commit
It seems that after these changes, the net.ipv4.conf.all.log_martians behavior became inconsistent, and the sysctl value began reverting to 1 despite being configured as 0 in VyOS.
Hi Boris,
It’s probably because this setting can be done from the firewall itself overwriting your ‘custom’ setting when a firewall change is done. You can use set firewall global-options log martians disable . Please see Global Options Firewall Configuration — VyOS rolling release (current) for more options.
Regards,
Sander
