I’m not sure if this is a bug or if I’m just missing something obvious. I’m using a 1.4-rolling-202210150526 AMD64 image. The system time off. Or rather, the hours/minutes are correct, but the time zone is wrong.
If I correct the time zone, then the hours/minutes shift accordingly and are now off. I don’t see anywhere to force a time sync with NTP servers.
I checked the BIOS time and the hours/minutes match local time, though I don’t see any time zone listed. I even tried adding the ntp.pool.org servers.
Am I missing something here? My WAN zone is set to default accept from from LOCAL and LAN. I don’t think my firewall is blocking it (everything else is working).
Here are the corresponding config parts:
vyos@vyos# show system time-zone
time-zone UTC
vyos@vyos# show system ntp
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
server 3.pool.ntp.org {
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
vyos@vyos# date
Sun 16 Oct 2022 05:34:39 PM UTC
The actual UTC time when I ran this command was 9:34 PM. The local time America/New_York time was 5:34 PM.
So your NTP isn’t working.
Do you have working NTP (EDIT: I meant DNS here but keeping the typo so the reply makes sense) so the NTP servers can be resolved?
I think you meant “working DNS”. Because if you did, you solved the problem! I forgot to set system name-server. Even though a DNS server is running on the router and working for all my clients it wasn’t able to resolve the NTP servers for itself.
