Tacacs - System Login
I configured TACACS in =
set system login tacacs
as bellow
set system login tacacs security-mode 'optional'
set system login tacacs server [...] key '[...]'
set system login tacacs source-address '192.168.1.251'
commit
Version Vyos =
Version:          VyOS 1.5-rolling-202312130023
Release train:    current
Built on:         Wed 13 Dec 2023 01:43 UTC
Build UUID:       ebe62d12-23c8-4566-9cf5-09eae32bdb62
Build commit ID:  8ce1ae8594f3ae
Architecture:     x86_64
Hardware S/N:     VMware-56 4d ca 93 7f 1f c2 d2-01 94 0d ca db 17 eb 42
Hardware UUID:    93ca4d56-1f7f-d2c2-0194-0dcadb17eb42
The Login authentication stay on local, need help ?
OK work with a local login and tacas login with option optional.
But the i 've got a limited access
some ideas about TACACS, issue ?
It’s not noted in the TACACS section, but is noted in the RADIUS section, that without the priv-lvl=15 attribute/value in the response that the user does not have admin privileges. You also need the service=shell attribute/value pair.
