Hi guys
int he past, I had a script in /config/scripts which needed to run every 5 minutes.
As vyatta cleared the crontab with every boot, I made use out of the vyatta-postconfig-bootup.script script:
grep -q updater.sh /etc/crontab 2> /dev/null || echo "*/5 * * * * vyatta sudo /config/scripts/updater.sh" >> /etc/crontab
checking the /etc/crontab, it seems that this still works, as the crontab file gets updated with the needed command:
But: it doesn’t run.
I searched a bit and have seen that vyos has meanwhile integrated a task scheduler (GREAT idea).
How exactly does it work? I checked the wiki, but there is only a config guide.
Is any cron file updated? which one?
as you can see I run the script as user “vyatta” (is this user still there?) which in turn runs a sudo.
after a while I checked messages and see the following:
Dec 22 11:41:01 vyattahome cron[2000]: Error: bad username; while reading /etc/crontab
Hmm, really need to understand it a bit more
thanks
Andre
vyatta user is now vyos.
I would recommend doing it with task scheduler. Just have it run your script
http://vyos.net/wiki/Task_scheduler
Hi
ahh, vyatta is now vyos … first “problem”
I have seen the scheduler (like it), but how do I get a “sudo” in there?
this is the config:
task-scheduler {
task TunnelUpdate {
executable {
path /config/scripts/updater.sh
interval 5
and this is the script:
#!/bin/vbash
##ip tunnel updating script
cd /
cd /config/scripts
EXT_IPV4=`curl -s "http://v4.ipv6-test.com/api/myip.php"`
OLD_IPV4=`cat ipv4.txt`
if [ $OLD_IPV4 = $EXT_IPV4 ] ;then
echo "old and new ipv4 addr are the same ipv6 tunnel not updated"
echo "exiting"
exit 1
else
echo "external ip does not match, updating ipv6 tunnel"
echo $EXT_IPV4 > ipv4.txt
curl "http://ipv4.tunnelbroker.net/ipv4_end.php?ip=AUTO&pass=xxxxxxxx&apikey=yyyyyy&tid=zzzz"
echo "done, exiting"
exit 1
fi
user “vyos” should have access to it as it’s member of “vyattacfg” …
26083920 -rwxrwxr-x 1 adieball vyattacfg 14 Dec 23 03:35 ipv4.txt
26083921 -rwxrwxr-x 1 adieball vyattacfg 578 Jul 1 16:27 updater.sh
anything I’m missing here?
thanks
Andre
I don’t understand what process here needs sudo at all?
I would think that you would want to store this text file in the vyos user home directory where it owns the directory.
Hi
I learned that only stuff within /config is preserved when upgrading. Is this not true anymore?
works like a charm, even leaving the script in “config"scripts”. The problem was the user vyatta vs. vyos
thanks
