Translate cisco to vyos
I need help to translate this policy
Interface fa0/0.2
service-policy input QPM_MARCADO
policy-map QPM_MARCADO
description Politica de marcado de trafico.
class QPM_MARCART
set ip dscp ef
class GUP
drop
class WU
drop
class WU2
drop
class WU-DOS
drop
class WU-TRES
drop
class WU-CUATRO
drop
class class-default
set ip dscp af21
class-map match-any QPM_MARCART
description Politica de marcado de trafico real time: video, voz, monitoreo y gestion.
match access-group name QPM_RTACL
class-map match-all GUP
match protocol http host “symantec”
match access-group name PROXY-SYM
class-map match-all WU2
match access-group name PROXY-WU2
match protocol http host “delivery”
class-map match-all WU-TRES
match access-group name PROXY-TRES
match protocol http host “download”
class-map match-all WU-CUATRO
match access-group name PROXY-CUATRO
match protocol http host “emdl.ws”
match protocol http host “windowsupdate”
ip access-list extended QPM_RTACL
permit ip any 10.10.10.0 0.0.0.255
permit ip any 10.10.20.0 0.0.0.255
permit ip any host 10.255.255.254
ip access-list extended PROXY-WU
permit ip any host 10.30.28.25 time-range BUSSINESS_HOURS
ip access-list extended PROXY-WU2
ip access-list extended PROXY-SYM
ip access-list extended PROXY-TRES
ip access-list extended PROXY-CUATRO
periodic weekdays 8:00 to 19:00
thanks
Hi @damianventre,
I think you can try to translate it using Policy Based Routing. You will be able to configure action drop, set dscp values, match addresses, ports and also use time to specify the times when the routing policy will take place:
vyos@vyos# set policy route TIME rule 10 time
Possible completions:
   monthdays    Monthdays to match rule on
   startdate    Date to start matching rule
   starttime    Time of day to start matching rule
   stopdate     Date to stop matching rule
   stoptime     Time of day to stop matching rule
   utc          Interpret times for startdate, stopdate, starttime and stoptime to be UTC
   weekdays     Weekdays to match rule on
Please note that, when using time, every value you set will be ANDed.
