Hello Team,
I am running Vyos 1.2.3 on bare-metal.
while entering the config mode i get the following
MSM@k7hsq18i:~$ config
fusermount: too many FUSE filesystems mounted; mount_max=N can be set in /etc/fuse.conf
When i check the df -kh i get the below result:
MSM@k7hsq18i:/config/archive$ df -kh
df: ‘/opt/vyatta/config/tmp/new_config_9872’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_20730’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_21457’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_21459’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_27393’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_32033’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_32583’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17120’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17117’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_31352’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17861’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_29729’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_29726’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_18717’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_19182’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_8184’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_8189’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_25084’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_5011’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_6815’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_9603’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_9606’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_9668’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_27345’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_27351’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_31997’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_18774’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_6248’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_13279’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_14349’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_14420’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_26279’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1496’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1563’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_3774’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_3773’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_4751’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_4752’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_12323’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_13096’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_28037’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_23559’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_10383’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_14210’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_14211’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_18313’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17097’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17096’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_20591’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_30105’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_30107’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_8335’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_8887’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_16265’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_16264’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_16697’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_18639’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_11945’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_12003’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_16299’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_22789’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_23451’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_29662’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1896’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1900’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_24084’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_12668’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_12751’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1341’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_13716’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_15780’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_29110’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_10186’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_14956’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_15038’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_15210’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_18780’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_26281’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_26016’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_26632’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_1319’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_8067’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17617’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_17689’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_671’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_719’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_13240’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_26736’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_28076’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_28078’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_16313’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_4520’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_4132’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_3329’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_11314’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_11375’: Transport endpoint is not connected
df: ‘/opt/vyatta/config/tmp/new_config_354’: Transport endpoint is not connected
Can someone point out what can cause this?
Best Wishes,
