Was able to install cifs-utils through apt-get, however when running the mount command, I am getting an error stating that cifs filesystem is not supported by the system.
sudo mount -t cifs \\\\10.10.30.254\\backup\\router -o username=xxx,password=xxxx,vers=3.0 /mnt/config-backup
mount error: cifs filesystem not supported by the system
apt-get reports it is installed
cifs-utils is already the newest version.
As well, the mount.cifs command returns invalid command.
Is this some limitation or am I simply missing something? I have no rebooted yet, perhaps this is the issue. Thanks!
