Hiya.
I’m trying to setup a site-to-site VPN between AWS and another cloud provider, with 2 VyOS instances on our AWS end connecting to an ASA at the remote end, with the tunnel failing over to the second VyOS if the first link goes down for any reason.
VyOS A –
------- ASA
VyOS B – /
The two VyOS devices are configured with connection-type “respond”, because we only want one tunnel up at a time, and we want the remote ASA to deal with failing over if/when it needs to.
The tunnel appears to come up properly (show vpn ipsec sa shows it as up on the first VyOS device, but down on the second), and all appears good to start with. However, after a fairly short while, pings from the remote network back into our AWS infrastructure stop working. If we send a ping back from AWS to the remote end, that goes through OK and suddenly pings back from them start again, for a while. The really confusing thing is that when we end up having to do that, the ASA at the remote end shows that the tunnel itself has been initiated by our VyOS, even though the configuration specifically says ‘respond’ at our end.
The relevant VyOS configuration is this (identical on both of our VyOS devices except for the local IP):
[code]vpn {
ipsec {
esp-group aws-remote-esp {
compression disable
lifetime 86400
mode tunnel
pfs dh-group5
proposal 1 {
encryption aes256
hash sha1
ike-group aws-remote-ike {
key-exchange ikev1
lifetime 28800
proposal 1 {
dh-group 2
encryption aes256
hash sha1
site-to-site {
peer xx.xx.xx.xx {
authentication {
mode pre-shared-secret
connection-type respond
default-esp-group aws-remote-esp
local-address xx.xx.xx.xx
tunnel 0 {
allow-nat-networks disable
allow-public-networks disable
local {
prefix xx.xx.xx.xx/16
remote {
prefix xx.xx.xx.xx/24
[/code]
But after we have to kick it with a ping from AWS, the ASA at the remote end is showing this:
6 IKE Peer: xx.xx.xx.xx
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
Note that it’s showing as responder, even though our end is configured to be respond only.
[code]vyos@VyOS-AMI:~$ show system image
The system currently has the following image(s) installed:
1: VyOS-1.1.7 (default boot) (running image)
[/code]
