Unable to get DNAT to work on pseudo-ethernet
Hi All,
As I prep for a new Kube install, I am adding a pseudo-ethernet interface. I can ping the external interface peth3 without issue from our side of the network, yet I can’t seem to get DNAT to pass. I’m not sure where to look; perhaps you could check my configuration. Sorry, it’s a bit of a mess right now. I’m working on cleaning it up as I learn more. My next firewall change will be to move to zone-based. Anyhow, here’s my configuration: I appreciate any input. I’ve tried for hours without any luck. I’m on Rolling 1.5, latest.
firewall {
    global-options {
        source-validation strict
        state-policy {
            established {
                action accept
            invalid {
                action drop
            related {
                action accept
        twa-hazards-protection enable
    group {
        interface-group LAN {
            interface eth2
        interface-group WAN {
            description "250 Address"
            interface eth3
        interface-group WAN2 {
            description "252 Address"
            interface peth3
        network-group NET-INSIDE-v4 {
            network xxx.xxx.25.0/24
    ipv4 {
        input {
            filter {
                default-action drop
                default-log
                rule 1 {
                    action accept
                    description "Allow all from LAN"
                    inbound-interface {
                        group LAN
                rule 20 {
                    action jump
                    destination {
                        port 2237
                    jump-target VyOS_MANAGEMENT
                    protocol tcp
                rule 30 {
                    action accept
                    description "Allow ICMP"
                    limit {
                        rate 5/second
                    protocol icmp
                rule 40 {
                    action accept
                    destination {
                        port 53
                    protocol tcp_udp
                        group {
                rule 50 {
                    action accept
                        address xxx.xxx.0.0/8
                rule 60 {
                    action accept
                    destination {
                        address xxx.xxx.25.56
                        port 53764
                    inbound-interface {
                        group WAN
                    protocol tcp
                rule 70 {
                    action accept
                    destination {
                        address xxx.xxx.25.76
                        port 443
                    inbound-interface {
                        group WAN
                    protocol tcp
                rule 80 {
                    action accept
                    description "NPM 80"
                    destination {
                        port 80
                    inbound-interface {
                        group WAN
                    protocol tcp
                rule 90 {
                    action accept
                    description Plex
                    destination {
                        address xxx.xxx.25.51
                        port 32400
                    inbound-interface {
                        group WAN
                    protocol tcp
                rule 100 {
                    action accept
                    description Tailscale
                    destination {
                        address xxx.xxx.25.64
                        port 41641
                    inbound-interface {
                        group WAN
                    protocol udp
                rule 110 {
                    action accept
                    description "Speedtest Port 3000"
                    destination {
                        address xxx.xxx.25.71
                        port 3002
                    inbound-interface {
                        group WAN
                    protocol tcp
                rule 120 {
                    action accept
                    description "Test Extenal to New IP"
                    destination {
                        port 3002
                    inbound-interface {
                        group WAN2
                    protocol tcp
        name VyOS_MANAGEMENT {
            default-action return
            rule 15 {
                action accept
                inbound-interface {
                    group LAN
            rule 20 {
                action drop
                inbound-interface {
                    group WAN
        disable
        hw-id xx:xx:xx:xx:xx:4e
        disable
        hw-id xx:xx:xx:xx:xx:4f
    ethernet eth2 {
        address xxx.xxx.25.1/24
        description LAN
        disable-flow-control
        hw-id xx:xx:xx:xx:xx:87
        ip {
            adjust-mss clamp-mss-to-pmtu
            arp-cache-timeout 60
        ipv6 {
            address {
                no-default-link-local
            disable-forwarding
        offload {
            gro
            gso
            rps
        ring-buffer {
            rx 128
            tx 128
    ethernet eth3 {
        address xxx.xxx.0.250/27
        hw-id xx:xx:xx:xx:xx:88
        ip {
        ipv6 {
            address {
            disable-forwarding
        offload {
            gro
            gso
            rps
        ring-buffer {
            rx 128
            tx 128
    loopback lo {
    pseudo-ethernet peth3 {
        address xxx.xxx.0.252/27
        description "252 WAN"
        ip {
        ipv6 {
            address {
            disable-forwarding
        source-interface eth3
nat {
    destination {
        rule 100 {
            description qBittorrent
            destination {
                port 53764
            inbound-interface {
                group WAN
            protocol tcp
            translation {
                port 53764
        rule 110 {
            description NPM
            destination {
                port 443
            inbound-interface {
                group WAN
            protocol tcp
            translation {
                port 443
        rule 120 {
            destination {
                port 443
            inbound-interface {
                group WAN
            protocol tcp
            translation {
                port 80
        rule 130 {
            description Plex
            destination {
                port 40402
            inbound-interface {
                group WAN
            protocol tcp
            translation {
                port 32400
        rule 150 {
            destination {
                port 41641
            inbound-interface {
                group WAN
            protocol udp
            translation {
                port 41641
        rule 160 {
            destination {
                port 3000
            inbound-interface {
                group WAN
            log
            protocol tcp
            translation {
                port 3002
        rule 170 {
            destination {
                port 3000
            inbound-interface {
                group WAN2
            log
            protocol tcp
            translation {
                port 3002
        rule 100 {
            outbound-interface {
                name eth3
                address xxx.xxx.25.0/24
            translation {
                address masquerade
        rule 110 {
                name peth3
            translation {
                address masquerade
protocols {
    static {
        route xxx.xxx.0.0/0 {
            next-hop xxx.xxx.0.249 {
service {
    dns {
        forwarding {
            allow-from xxx.xxx.25.0/24
            cache-size 0
            domain xxx.xxx.16.172.in-addr.arpa {
                name-server xxx.xxx.25.20 {
                name-server xxx.xxx.25.21 {
            domain cotb.local.lan {
            domain cotb.syberlogic.com {
            exclude-throttle-address xxx.xxx.25.0/24
            listen-address xxx.xxx.25.1
            name-server xxx.xxx.1.1 {
            name-server xxx.xxx.8.8 {
    lldp {
        interface eth3 {
        interface peth3 {
    ntp {
        allow-client xxxxxx
        server xxxxx.tld {
        server xxxxx.tld {
        server xxxxx.tld {
    ssh {
        port 2237
system {
    config-management {
        commit-archive {
            location xxxxxx
            source-address xxx.xxx.25.1
        commit-revisions 1000
    conntrack {
        flow-accounting
        log {
            other {
                destroy
                new
                update
            tcp {
                destroy
                new
                update
            udp {
                destroy
                new
                update
        modules {
            ftp
            h323
            sip
        table-size 1000000
    console {
        device ttyS0 {
            speed 115200
    domain-name xxxxxx
    domain-search xxxxxx
    host-name xxxxxx
    ip {
        arp {
            table-size 32768
        tcp {
            mss {
                probing on-icmp-black-hole
    login {
        user xxxxxx {
            authentication {
                encrypted-password xxxxxx
    logs {
        logrotate {
            messages {
                max-size 5
    option {
        kernel {
            disable-mitigations
            disable-power-saving
        performance throughput
        reboot-on-panic
        root-partition-auto-resize
        startup-beep
        time-format 24-hour
    syslog {
        global {
            facility all {
            facility local7 {
    time-zone America/Los_Angeles
    update-check {
        auto-check
        url xxxxxx
Thanks again!
Keith
Bumping, this is a hard stop for me. I want to do a zone-based firewall, yet without this capability, I am kind of out of luck.
Thanks again,
Keith
Maybe packets from WAN always enter on eth3, not the peth interface
If so dNAT rules on peth are ineffective.
I always try to avoid peth , its use case is pulling 2nd DHCP address from ISP using different MAC address
why not assign both WAN addresses to eth3?
I believe the root of the issue might indeed be what you’re suggesting, though I’m not entirely certain that it captures the whole picture. It appears that while packets are successfully arriving via PETH3, they seem to be lost when trying to return. My suspicion is that this might be due to internal asymmetric routing affecting LAN clients. Given that their gateway is set to eth3, my guess is that their responses are being sent via eth3 and subsequently dropped. While some firewalls manage this scenario without any issues, I’m not entirely confident about Vyos’s capabilities in this regard.
The reason I’m considering adding a secondary IP is to enable more than one client to handle packets on the same external and internal ports (80/443). I’ve been contemplating whether Vyos’s internal load balancer might offer a solution, though I’m uncertain if it’s the optimal approach in this context. Adding another IP to the primary could be a workaround, but I’m skeptical it would fully address the problem, especially since I’m not too familiar with the nuances of peth interfaces and if they’re causing an issue or if I’m just running up against a routing problem.
I’m planning to experiment with your idea of a secondary IP to see if it offers a straightforward fix, though my expectations are tempered. While employing the Vyos load balancer could introduce greater flexibility, it also presents additional complexity. My goal is to direct traffic into a Kubernetes cluster, and ideally, I’d prefer using an internal cluster load balancer for redundancy. However, considering some of my clients are external to the cluster, this necessitates further consideration.
I’m considering using the load balancer to solve for the initial issue while also implementing policy-based routing to be sure the packets are routed out over the correct interface. This seems rather complex; therefore, I’d appreciate further insight.
Is the Vyos load balancer itself perhaps the solution? Considering all of my traffic is coming from the WAN, I suppose that, being that I have a single firewall, it doesn’t really affect my overall redundancy. I could also consider a load balancer inside the LAN, yet this is one more system to maintain. I’d rather keep it as straight-forward as possible.
I’d appreciate any insights or recommendations you might have. Admittedly, this topic stretches beyond my current networking expertise, and I’m aiming for the most efficient configuration possible.
Thank you immensely for your support!
