I’ve been labbing a DMVPN setup with a Cisco Hub (on a DSL line) and two VyOS Spokes (both connected at my home lab same Gig VLAN). I’m running BGP between the routers. Unexpectedly, all spoke-to-spoke traffic appears to be flowing through the hub.
Ping times from Spokes to Hub is approximately 75ms.
Ping times from Spoke to Spoke (public IP’s) are sub millisecond (same Gigabit LAN)
Ping times from Spoke to Spoke (internal encrypted LAN) are approximately 75ms.
I can watch the flows on the Cisco Hub and definitely see the spoke-to-spoke traffic showing up on the Hub TUN interface.
HUB 10.0.0.1
Spoke 1 10.0.0.2
Spoke 2 10.0.0.4
I keep seeing this in the Spoke 1 Log:
Apr 3 08:46:19 Spoke1 pluto[4187]: “10.0.0.2-to-10.0.0.4”: deleting connection
Apr 3 08:46:19 Spoke1 pluto[4187]: two interfaces match “10.0.0.2-to-10.0.0.4” (eth0, eth0)
Apr 3 08:46:19 Spoke1 pluto[4187]: added connection description “10.0.0.2-to-10.0.0.4”
Apr 3 08:46:19 Spoke1 opennhrp[28685]: [10.0.0.4] Peer up script failed: exitstatus 1
Spoke 2 shows no such entries.
It would appear that the tunnels build:
Spoke1# run sho nhrp tun
Status: ok
Interface: tun0
Type: local
Protocol-Address: 10.0.0.255/32
Alias-Address: 10.0.0.2
Flags: up
Interface: tun0
Type: local
Protocol-Address: 10.0.0.2/32
Flags: up
Interface: tun0
Type: negative
Protocol-Address: 10.0.0.4/32
NBMA-Address:
Flags: used
Expires-In: 0:25
Interface: tun0
Type: static
Protocol-Address: 10.0.0.1/24
NBMA-Address:
Flags: used up
Spoke2 run sho nhrp tun
Status: ok
Interface: tun0
Type: local
Alias-Address: 10.0.0.4
Flags: up
Interface: tun0
Type: local
Flags: up
Interface: tun0
Type: cached
NBMA-Address:
Flags: used up
Expires-In: 64:52
Interface: tun0
Type: static
NBMA-Address:
Flags: used up
Config bits:
Spoke#sho int tun tun0
address
encapsulation gre
local-ip
multicast enable
parameters {
ip {
key 0
Spoke# sho protocols nhrp
tunnel tun0 {
cisco-authentication
map 10.0.0.1/24 {
cisco
nbma-address
register
multicast nhs
redirect
shortcut
Cisco HUB:
interface Tunnel0
ip address 10.0.0.1 255.255.255.0
no ip redirects
ip flow ingress
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
ip nhrp registration timeout 75
ip nhrp shortcut
load-interval 30
tunnel source Dialer1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile DMVPN
end
Without “shortcut” on the spokes, the ping times from spoke-to-spoke internal LANs doubles (~75ms to ~150ms).
Am I just misunderstanding DMPVN or is something really not working right here?
