Hello fellows, how are you?
Please let me know if this issue below is a BUG. I’m trying to do a upgrade from vyos 1.1.8 to latest rolling version, following the steps below:
My current version:
show version
Version: VyOS 1.1.8
Description: VyOS 1.1.8 (helium)
Copyright: 2017 VyOS maintainers and contributors
Built by: [email protected]
Built on: Sat Nov 11 12:59:07 UTC 2017
Build ID: 1711111259-b483efc
System type: x86 32-bit
Boot via: image
HW model: Series 3500
HW S/N: 1XS4TR1
HW UUID: 44454C4C-5800-1053-8034-B1C04F545231
Uptime: 04:53:41 up 36 min, 2 users, load average: 0.28, 0.30, 0.37
Procedures:
add system image VyOS Community
Output:
Trying to fetch ISO file from VyOS Community
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 409M 100 409M 0 0 13.7M 0 0:00:29 0:00:29 --:–:-- 16.3M
ISO download succeeded.
Checking for digital signature file…
0 0 0 0 0 0 0 0 --:–:-- --:–:-- --:–:-- 0
curl: (22) The requested URL returned error: 404
Unable to fetch digital signature file.
Do you want to continue without signature check? (yes/no) [yes] y
Checking MD5 checksums of files on the ISO image…OK.
Error trying to mount a partition/directory.
Please see /tmp/install-16884.log for details.
Failed to mount the squashfs image.
Exiting…
cat /tmp/install-16884.log
mount -o loop,ro /mnt/cdrom/live/filesystem.squashfs /mnt/cdsquash
mount: wrong fs type, bad option, bad superblock on /dev/loop2,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
Trying again:
Output:
100 409M 100 409M 0 0 14.5M 0 0:00:28 0:00:28 --:–:-- 17.5M
0 0 0 0 0 0 0 0 --:–:-- 0:00:01 --:–:-- 0
Please see /tmp/install-17362.log for details.
Exiting…
vyatta@ositel-C:~$ cat /tmp/install-17362.log
dmesg | tail or so
So, how to proceed to do a safe upgrade? I’m trying this because some reason my system use high memory, keep low allow memory.
With Best Regards
Josue
