I have done an update of a test installation of a vyos running inside a vm on a proxmox server. The System was on 1.3.4 and did nothing special only. Have a static IP on lan, a wan via dhcp and then nat the internal network to the outside network.
The following commands where issued:
vyos@vyos1.sh.local:~$ show version
Version: VyOS 1.3.4
Release train: equuleus
Built by: Sentrium S.L.
Built on: Fri 13 Oct 2023 12:10 UTC
Build UUID: 0b20543f-d1b6-49e5-b36b-95a069c63788
Build commit ID: 986c77ac08c552
Architecture: x86_64
Boot via: installed image
System type: KVM guest
Hardware vendor: QEMU
Hardware S/N:
Hardware UUID: a8642992-8049-4365-8a32-e973353cb1b8
vyos@vyos1.sh.local:~$ add system image https://cdn.vyos.io/1.4.0-epa3/generic-iso/<id>/vyos-1.4.0-epa3-amd64.iso
Checking SHA256 checksums of files on the ISO image... OK.
Done!
What would you like to name this image? [1.4.0-epa3]:
OK. This image will be named: 1.4.0-epa3
Installing "1.4.0-epa3" image.
Copying new release files...
Would you like to save the current configuration
directory and config file? (Yes/No) [Yes]:
Copying current configuration...
Would you like to save the SSH host keys from your
current configuration? (Yes/No) [Yes]:
Copying SSH keys...
Running post-install script...
Setting up grub configuration...
Done.
vyos@vyos1.sh.local:~$ reboot
After the reboot I was not able to ssh in it.
When I did a show interfaces on the console of the vm, both interface eth0 and eth1 didn’t have an IP. Also show configuration didn’t show and interface config. Everything else seems to bet there. (NAT, Firewalls…). I have a save of the converted config.
A reboot to the 1.3.4 version worked fine and everything is up again.
