VyOS includes HAproxy to be used for loadbalancer tasks.
For added redundancy this can be combined with VRRP but how can then the states of the loadbalancing itself be shared between the VyOS hosts?
Another drawback with VRRP is that you will then have an active/passive setup as in all traffic passes through a single VyOS until that one is no longer available.
In order to do active/active I could just let the clients use dns roundrobin to connect to whatever available loadbalaner there is.
But Im thinking are there some other nifty ways to deal with this?
For example letting each VyOS announce through BGP and be part of an anycasted IP to which the clients connects to in order to end up at a working loadbalancer?
Are there some other ways to deal with active/active and still have each client end up at a physical VyOS instance so the client traffic gets loadbalanced to the same server if you use stickyness (which otherwise will be lost if one connection ends up at VyOS_1 doing its loadbalancing and then VyOS_2 for the next tcp/udp-session where you might get loadbalanced to a different server)?
Can the BGP announcement include some data that these VyOS hosts should not be shared through ECMP but routed to one at a time based on 5-tuple or such?
Im thinking otherwise announcing through BGP to be part of a anycasted IP would still have the risk of one connection ends up at VyOS_1 and the other at VyOS_2 from the same client and unless HAproxy includes some way of share stickyness between the HAproxy instances the same client would very likely end up at different servers.
How have you solved the need of active/active loadbalancing?
My main concerns is that I want to basically loadbalance the loadbalancers along with be able to keep stickyness running (a single client ends up at a random server but then all following connections from this client for the next hour or so as TTL will end up at the same server as long as this server is alive). And at the same time have as short time as possible for when a loadbalancer malfunctions that it should be rotated out of the list of available loadbalancers in order to not blackhole new connections during this transition time.
