Took some time to try and build the stable ISO using docker today. It keeps failing with “broken vyos-world” errors. According to the console output of your build system, they are failing with the same issue. https://ci.vyos.net/job/vyos-build/
https://ci.vyos.net/job/vyos-build/job/crux/lastFailedBuild/console
Broken vyos-world:amd64 Depends on vyatta-cfg-system [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cfg-system:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated dialog:amd64
Re-Instated libnetaddr-ip-perl:amd64
Re-Instated libnss-mapuser:amd64
Re-Instated radius-shell:amd64
Re-Instated libpam-radius-auth:amd64
Re-Instated vyatta-config-migrate:amd64
Re-Instated libcurl3:amd64
Re-Instated curl:amd64
Re-Instated libsocket6-perl:amd64
Re-Instated libsort-versions-perl:amd64
Re-Instated libfile-sync-perl:amd64
Re-Instated libboost-system1.55.0:amd64
Re-Instated libboost-filesystem1.55.0:amd64
Re-Instated libperl5.20:amd64
Re-Instated libvyatta-cfg1:amd64
Re-Instated unionfs-fuse:amd64
Re-Instated vyatta-cfg:amd64
Re-Instated libestr0:amd64
Re-Instated libjson-c2:amd64
Re-Instated liblogging-stdlog0:amd64
Re-Instated liblognorm1:amd64
Re-Instated rsyslog:amd64
Re-Instated bridge-utils:amd64
Re-Instated ed:amd64
Re-Instated installation-report:amd64
Re-Instated dmidecode:amd64
Re-Instated laptop-detect:amd64
Re-Instated logrotate:amd64
Re-Instated mgetty:amd64
Re-Instated tasksel-data:amd64
Re-Instated tasksel:amd64
Re-Instated tcpdump:amd64
Re-Instated mdadm:amd64
Re-Instated libcommon-sense-perl:amd64
Re-Instated libjson-xs-perl:amd64
Re-Instated libparams-classify-perl:amd64
Re-Instated libmodule-runtime-perl:amd64
Re-Instated libtry-tiny-perl:amd64
Re-Instated libmodule-implementation-perl:amd64
Re-Instated libsub-exporter-progressive-perl:amd64
Re-Instated libvariable-magic-perl:amd64
Re-Instated libb-hooks-endofscope-perl:amd64
Re-Instated libpackage-stash-perl:amd64
Re-Instated libsub-identify-perl:amd64
Re-Instated libnamespace-clean-perl:amd64
Re-Instated libjson-any-perl:amd64
Re-Instated libnetwork-ipv4addr-perl:amd64
Re-Instated libnet-ipv6addr-perl:amd64
Re-Instated libnet-netmask-perl:amd64
Re-Instated libdata-validate-ip-perl:amd64
Re-Instated ddclient:amd64
Re-Instated libnet-ssleay-perl:amd64
Re-Instated libio-socket-ssl-perl:amd64
Re-Instated vyatta-biosdevname:amd64
Re-Instated libnl-3-200:amd64
Re-Instated libnl-genl-3-200:amd64
Re-Instated ipvsadm:amd64
Re-Instated libdaemon0:amd64
Re-Instated radvd:amd64
Re-Instated libnl-route-3-200:amd64
Re-Instated hostapd:amd64
Re-Instated libparted2:amd64
Re-Instated parted:amd64
Re-Instated libpam-cap:amd64
Re-Instated libefivar0:amd64
Re-Instated efibootmgr:amd64
Re-Instated grub-efi-amd64-bin:amd64
Re-Instated dosfstools:amd64
Re-Instated gdisk:amd64
Re-Instated bash-completion:amd64
Re-Instated vyatta-cfg-system:amd64
Broken vyos-world:amd64 Depends on vyatta-op [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-op:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated kbd:amd64
Re-Instated console-setup-linux:amd64
Re-Instated traceroute:amd64
Re-Instated libc-ares2:amd64
Re-Instated libyang0.16:amd64
Re-Instated frr:amd64
Re-Instated less:amd64
Re-Instated libterm-readkey-perl:amd64
Re-Instated libwant-perl:amd64
Re-Instated libio-prompt-perl:amd64
Re-Instated at:amd64
Re-Instated net-tools:amd64
Re-Instated vyatta-op:amd64
Broken vyos-world:amd64 Depends on vyatta-config-mgmt [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-config-mgmt:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-config-mgmt:amd64
Broken vyos-world:amd64 Depends on vyatta-cfg-firewall [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cfg-firewall:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libopts25:amd64
Re-Instated ntp:amd64
Re-Instated libsensors4:amd64
Re-Instated libsnmp-base:amd64
Re-Instated libsnmp30:amd64
Re-Instated snmpd:amd64
Re-Instated libnfnetlink0:amd64
Re-Instated iptables:amd64
Re-Instated libipset3:amd64
Re-Instated ipset:amd64
Re-Instated libswitch-perl:amd64
Re-Instated libsnmp-perl:amd64
Re-Instated vyatta-cfg-firewall:amd64
Broken vyos-world:amd64 Depends on vyatta-op-firewall [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-op-firewall:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated xsltproc:amd64
Re-Instated vyatta-op-firewall:amd64
Broken vyos-world:amd64 Depends on vyatta-cfg-op-pppoe [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cfg-op-pppoe:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated ppp:amd64
Re-Instated pppoe:amd64
Re-Instated vyatta-cfg-op-pppoe:amd64
Broken vyos-world:amd64 Depends on vyatta-cfg-qos [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cfg-qos:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-cfg-qos:amd64
Broken vyos-world:amd64 Depends on vyatta-op-qos [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-op-qos:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libtree-simple-perl:amd64
Re-Instated vyatta-op-qos:amd64
Broken vyos-world:amd64 Depends on vyatta-cfg-quagga [ amd64 ] < none > ( none )
Broken vyos-world:amd64 Depends on vyatta-op-quagga [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-op-quagga:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-op-quagga:amd64
Broken vyos-world:amd64 Depends on vyatta-cfg-vpn [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cfg-vpn:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libstrongswan:amd64
Re-Instated strongswan-starter:amd64
Re-Instated strongswan-libcharon:amd64
Re-Instated strongswan-charon:amd64
Re-Instated strongswan:amd64
Re-Instated strongswan-swanctl:amd64
Re-Instated libstrongswan-extra-plugins:amd64
Re-Instated libcharon-extra-plugins:amd64
Re-Instated libcrypt-openssl-bignum-perl:amd64
Re-Instated libcrypt-openssl-rsa-perl:amd64
Re-Instated libpython3.4-minimal:amd64
Re-Instated python3.4-minimal:amd64
Re-Instated libmpdec2:amd64
Re-Instated libpython3.4-stdlib:amd64
Re-Instated python3.4:amd64
Re-Instated python3-minimal:amd64
Re-Instated libpython3-stdlib:amd64
Re-Instated dh-python:amd64
Re-Instated python3:amd64
Re-Instated python3-vici:amd64
Re-Instated vyatta-cfg-vpn:amd64
Broken vyos-world:amd64 Depends on vyatta-op-vpn [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-op-vpn:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-op-vpn:amd64
Broken vyos-world:amd64 Depends on vyatta-cluster [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-cluster:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libltdl7:amd64
Re-Instated libpils2:amd64
Re-Instated libplumb2:amd64
Re-Instated libheartbeat2:amd64
Re-Instated libplumbgpl2:amd64
Re-Instated libstonith1:amd64
Re-Instated libdbus-glib-1-2:amd64
Re-Instated liblrm2:amd64
Re-Instated libopenhpi2:amd64
Re-Instated libopenipmi0:amd64
Re-Instated cluster-glue:amd64
Re-Instated iproute:amd64
Re-Instated libgnutls-openssl27:amd64
Re-Instated iputils-ping:amd64
Re-Instated libmpfr4:amd64
Re-Instated libsigsegv2:amd64
Re-Instated gawk:amd64
Re-Instated libxml2-utils:amd64
Re-Instated libnet1:amd64
Re-Instated resource-agents:amd64
Re-Instated heartbeat:amd64
Re-Instated vyatta-cluster:amd64
Broken vyos-world:amd64 Depends on vyatta-conntrack [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-conntrack:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libnetfilter-conntrack3:amd64
Re-Instated conntrack:amd64
Re-Instated conntrack-helpers:amd64
Re-Instated libnetfilter-cthelper0:amd64
Re-Instated libnetfilter-cttimeout1:amd64
Re-Instated nfct:amd64
Re-Instated vyatta-conntrack:amd64
Broken vyos-world:amd64 Depends on vyatta-conntrack-sync [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-conntrack-sync:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libnetfilter-queue1:amd64
Re-Instated conntrackd:amd64
Re-Instated vyatta-conntrack-sync:amd64
Broken vyos-world:amd64 Depends on vyatta-eventwatch [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-eventwatch:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libxml-namespacesupport-perl:amd64
Re-Instated libxml-sax-base-perl:amd64
Re-Instated libxml-sax-perl:amd64
Re-Instated libxml-libxml-perl:amd64
Re-Instated libxml-simple-perl:amd64
Re-Instated eventwatchd:amd64
Re-Instated vyatta-eventwatch:amd64
Broken vyos-world:amd64 Depends on vyatta-ipv6-rtradv [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-ipv6-rtradv:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-ipv6-rtradv:amd64
Broken vyos-world:amd64 Depends on vyatta-lldp [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-lldp:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libevent-2.0-5:amd64
Re-Instated lldpd:amd64
Re-Instated vyatta-lldp:amd64
Broken vyos-world:amd64 Depends on vyatta-nat [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-nat:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-nat:amd64
Broken vyos-world:amd64 Depends on vyatta-netflow [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-netflow:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libjansson4:amd64
Re-Instated mysql-common:amd64
Re-Instated libmysqlclient18:amd64
Re-Instated libnetfilter-log1:amd64
Re-Instated libpq5:amd64
Re-Instated pmacct:amd64
Re-Instated vyatta-netflow:amd64
Broken vyos-world:amd64 Depends on vyatta-openvpn [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-openvpn:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated liblzo2-2:amd64
Re-Instated libpkcs11-helper1:amd64
Re-Instated openvpn:amd64
Re-Instated gnustep-common:amd64
Re-Instated ca-certificates:amd64
Re-Instated gnustep-base-common:amd64
Re-Instated libavahi-common-data:amd64
Re-Instated libavahi-common3:amd64
Re-Instated libavahi-client3:amd64
Re-Instated libobjc4:amd64
Re-Instated libgnustep-base1.24:amd64
Re-Instated gnustep-base-runtime:amd64
Re-Instated openvpn-auth-ldap:amd64
Re-Instated openvpn-auth-radius:amd64
Re-Instated libfile-slurp-perl:amd64
Re-Instated vyatta-openvpn:amd64
Broken vyos-world:amd64 Depends on vyatta-ravpn [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-ravpn:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated xl2tpd:amd64
Re-Instated bcrelay:amd64
Re-Instated pptpd:amd64
Re-Instated libfreeradius-client2:amd64
Re-Instated vyatta-ravpn:amd64
Broken vyos-world:amd64 Depends on vyatta-wanloadbalance [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-wanloadbalance:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-wanloadbalance:amd64
Broken vyos-world:amd64 Depends on vyatta-webproxy [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-webproxy:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libecap2:amd64
Re-Instated squid-langpack:amd64
Re-Instated squid3-common:amd64
Re-Instated squid3:amd64
Re-Instated squidclient:amd64
Re-Instated squidguard:amd64
Re-Instated vyatta-webproxy:amd64
Broken vyos-world:amd64 Depends on vyatta-wireless [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-wireless:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-bash:amd64
Re-Instated libpcsclite1:amd64
Re-Instated wpasupplicant:amd64
Re-Instated iw:amd64
Re-Instated wireless-regdb:amd64
Re-Instated crda:amd64
Re-Instated vyatta-wireless:amd64
Broken vyos-world:amd64 Depends on vyatta-wirelessmodem [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-wirelessmodem:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated libjim0.75:amd64
Re-Instated libusb-1.0-0:amd64
Re-Instated usb-modeswitch-data:amd64
Re-Instated usb-modeswitch:amd64
Re-Instated vyatta-wirelessmodem:amd64
Broken vyos-world:amd64 Depends on vyatta-zone [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyatta-zone:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyatta-zone:amd64
Broken vyos-world:amd64 Depends on vyos-nhrp [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyos-nhrp:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated vyos-opennhrp:amd64
Re-Instated vyos-nhrp:amd64
Broken vyos-world:amd64 Depends on vyos-1x [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyos-1x:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated accel-ppp:amd64
Re-Instated beep:amd64
Re-Instated libconfuse-common:amd64
Re-Instated libconfuse0:amd64
Re-Instated bmon:amd64
Re-Instated etherwake:amd64
Reinst Failed early because of libgnat-4.4:amd64
Reinst Failed early because of libgnat-4.6:amd64
Re-Instated gnat-4.9-base:amd64
Re-Instated libgnat-4.9:amd64
Re-Instated hvinfo:amd64
Re-Instated igmpproxy:amd64
Re-Instated libcidr0:amd64
Re-Instated ipaddrcheck:amd64
Re-Instated iputils-arping:amd64
Re-Instated isc-dhcp-relay:amd64
Re-Instated isc-dhcp-server:amd64
Re-Instated keepalived:amd64
Re-Instated libcarp-assert-perl:amd64
Re-Instated libcarp-assert-more-perl:amd64
Re-Instated libclass-data-inheritable-perl:amd64
Re-Instated libdevel-stacktrace-perl:amd64
Re-Instated libexception-class-perl:amd64
Re-Instated libfile-which-perl:amd64
Re-Instated libfile-homedir-perl:amd64
Re-Instated libclone-perl:amd64
Re-Instated libhash-merge-perl:amd64
Re-Instated libjson-perl:amd64
Re-Instated liblist-moreutils-perl:amd64
Re-Instated liblog-log4perl-perl:amd64
Re-Instated libmouse-perl:amd64
Re-Instated libmousex-nativetraits-perl:amd64
Re-Instated libmousex-strictconstructor-perl:amd64
Re-Instated libparse-recdescent-perl:amd64
Re-Instated libpath-tiny-perl:amd64
Re-Instated libpod-pom-perl:amd64
Re-Instated libalgorithm-diff-perl:amd64
Re-Instated libtext-diff-perl:amd64
Re-Instated libyaml-perl:amd64
Re-Instated libconfig-model-perl:amd64
Re-Instated libconfig-model-lcdproc-perl:amd64
Re-Instated lcdproc:amd64
Re-Instated libvyosconfig0:amd64
Re-Instated lsscsi:amd64
Re-Instated mdns-repeater:amd64
Re-Instated ntpdate:amd64
Re-Instated openssh-sftp-server:amd64
Re-Instated openssh-server:amd64
Re-Instated dns-root-data:amd64
Re-Instated publicsuffix:amd64
Re-Instated libboost-context1.55.0:amd64
Re-Instated libfstrm0:amd64
Re-Instated libprotobuf9:amd64
Re-Instated libsodium13:amd64
Re-Instated pdns-recursor:amd64
Re-Instated python3-bottle:amd64
Re-Instated python3-pkg-resources:amd64
Re-Instated python3-hurry.filesize:amd64
Re-Instated python3-isc-dhcp-leases:amd64
Re-Instated python3-markupsafe:amd64
Re-Instated python3-jinja2:amd64
Re-Instated python3-netifaces:amd64
Re-Instated python3-psutil:amd64
Re-Instated python3-pystache:amd64
Re-Instated python3-six:amd64
Re-Instated python3-tabulate:amd64
Re-Instated libpgm-5.1-0:amd64
Re-Instated libzmq3:amd64
Re-Instated python3-zmq:amd64
Re-Instated snmp:amd64
Re-Instated tftpd-hpa:amd64
Re-Instated libsmi2ldbl:amd64
Re-Instated libwsutil4:amd64
Re-Instated libwiretap4:amd64
Re-Instated libwireshark-data:amd64
Re-Instated libwireshark5:amd64
Re-Instated wireshark-common:amd64
Re-Instated tshark:amd64
Re-Instated udp-broadcast-relay:amd64
Re-Instated usbutils:amd64
Re-Instated vyos-intel-qat:amd64
Reinst Failed early because of wireguard-dkms:amd64
Re-Instated bc:amd64
Re-Instated wireguard-modules:amd64
Re-Instated wireguard-tools:amd64
Re-Instated wireguard:amd64
Re-Instated vyos-1x:amd64
Broken vyos-world:amd64 Depends on vyos-salt-minion [ amd64 ] < none -> 1.2.6 > ( contrib/net )
Considering vyos-salt-minion:amd64 1 as a solution to vyos-world:amd64 9998
Re-Instated python3-urllib3:amd64
Re-Instated bsdmainutils:amd64
Re-Instated dctrl-tools:amd64
Re-Instated python-crypto:amd64
Re-Instated python-zmq:amd64
Re-Instated libapt-inst1.5:amd64
Re-Instated python-apt-common:amd64
Re-Instated python-apt:amd64
Re-Instated python-six:amd64
Re-Instated python-dateutil:amd64
Re-Instated python-markupsafe:amd64
Re-Instated python-jinja2:amd64
Re-Instated python-msgpack:amd64
Re-Instated python-pkg-resources:amd64
Re-Instated python-chardet:amd64
Re-Instated python-urllib3:amd64
Re-Instated python-requests:amd64
Re-Instated libjs-jquery:amd64
Re-Instated libjs-underscore:amd64
Re-Instated libjs-sphinxdoc:amd64
Re-Instated python-concurrent.futures:amd64
Re-Instated python-pycurl:amd64
Re-Instated python-tornado:amd64
Re-Instated libyaml-0-2:amd64
Re-Instated python-yaml:amd64
Re-Instated python-systemd:amd64
Re-Instated python-psutil:amd64
Re-Instated salt-common:amd64
Re-Instated salt-minion:amd64
Re-Instated vyos-salt-minion:amd64
Done
debconf is already the newest version.
gnupg is already the newest version.
gpgv is already the newest version.
Some packages could not be installed. This may mean that you have
vyos-world : Depends: vyatta-cfg-quagga but it is not installable
P: Saving caches…
Reading package lists…
Building dependency tree…
Reading state information…
root@aaad08eb4dd1:/vyos#
