Using FastNetMon
Hello!
I am currently working on adding FastNetMon into our config with VyOS. I used the VyOS version of fastnetmon, but wanted to know if there is a way to enable a license key for FastNetMon?
Also, does VyOS auto ban attacks or do I need to make a script to handle the ban/unban?
Thanks!
We use a community version that doesn’t require any license key.
You have to add your own scripts/logic to block banned addresses
Thank you! Is there a way to set an access_key to use fastnetmon advanced? Or would I need to disable it on the VyOS config and then install it manually?
