Using firewall remote-group (ip|network list from url) in prerouting chains
I have a list of some government-based ips I route exclusively via tunnel.
However, to do so I require prerouting rule to mark packet, and then ip rule to route it to correct interface.
From what I understand right now it is impossible?
Maybe alternative solution for this kind of problem? (list is updated daily)
As a workaround perhaps you can inject that using ansible?
Maybe, a bit clunky since I don’t use ansible for IaC. I just want a daily updated ip list which i can use in prerouting chain.
Seems like it is limitation of vyos ? meaning i can use the same set in manual nft rule ?
