I used to use edgerouter lite. I was happy with its WAN-LAN throughput. But it’s openvpn performance was dismal. I decided to buy new hardware and try this out.
I bought the supermicro C2758 mini-itx motherboard with 8G of RAM, installed the latest 64 bit version image. I have set it up with the minimal config to just just test the throughput. I had no firewall rules set right now. Testing on 100M cable line, it gives me constantly 94M. While my netgear R7000 gives 170M.
I also tried to setup openvpn client with PIA, I am not able to.
But plain WAN-LAN speed is very poor. Any idea?
