HI.
Just installed vyos helium in a VM under VMware Workstation 10, on Windows Seven 64bit. I like the look of this a lot however…
I’m having an issue where by vyos can’t connect to another vm via the Host Only internal vnet I’ve set up. Windows also has a virtual adapter connected to this vnet but no connectivity between vyos and windows host either. Is there any known issue with these virtual networks and vyos under VMware Workstation?
For what it’s worth, the vnet is configured correctly, IP addresses, etc. I have other distros on vms that use it and connection between them and Windows host works. Physical bridged networks work on vyos too, just not this virtual one.
Thanks for any tips.
