Hi, just wanted to check if this is a bug or I am missing something. I am running VyOS 1.1.7 (helium) and using site-to-site VPN tunnels with vti interfaces. I noticed one strange behavior - even though the VPN tunnel goes down, the vti interface associated to it is still up - see the attachment (vti555). Is this a bug?
VPN tunnel DOWN, vti interface UP
afaik, vti interfaces are always in up state, so you can’t use them in floating routes logic.
otoh VTI interfaces are perfectly suited for using a routing protocol. If remote tunnel endpoint is unreachable , routing protocol will detect this and use different route (…if alternative path is available)
I have same problem with vti interfaces, only in 1.1.7 version.
1.0.2 (hydrogen):
[code]vyos@VHQnod2:~$ show interfaces | grep n0xx-xxxxxxx.org
vti8052000 172.16.52.13/30 A/D n0xx-xxxxxxx.org
vyos@VHQnod2:~$ show vpn ipsec sa peer xx.xx.xx2.xx
Peer ID / IP Local ID / IP
xx.xx.xx.xx xx.xx.xx.xx
Description: n0xx-xxxxxxx.org
Tunnel State Bytes Out/In Encrypt Hash NAT-T A-Time L-Time Proto
vti down n/a n/a n/a no 0 3600 all[/code]
1.1.7:
[code]vyos@HUB1nod2:~$ show interfaces | grep n0xx-xxxxxxx.org
vti8052000 172.16.52.5/30 u/u n0xx-xxxxxxx.org
vyos@HUB1nod2:~$ show vpn ipsec sa peer xx.xx.xx.xx
[/code]
So i’m very confuse it’s a “feature” or bug ?
