I found another issue related to VPP bonding and VLAN subinterfaces.
Reconfiguring a single subinterface on a bonded VPP interface causes all subinterfaces on the bond to go down, resulting in loss of connectivity across the entire bonded interface.
This makes the solution unstable in my environments.
vpp {
bonding vppbond0 {
hash-policy layer3+4
member {
interface eth6
interface eth7
interface eth8
interface eth9
mode 802.3ad
mtu 1500
vif 38 {
address 198.51.100.2/30
address 2001:db8:100::2/126
mtu 1500
vif 30 {
address 203.0.113.2/24
mtu 1500
Initial state:
vyos@r1# run show interfaces vpp
BondEthernet0 bond 02:fe:d9:33:87:4d 9000 up
BondEthernet0.38 bond 198.51.100.2/30 00:00:00:00:00:00 1500 up
BondEthernet0.30 bond 203.0.113.2/24 00:00:00:00:00:00 1500 up
Removing a single IPv6 address from one VLAN subinterface:
delete interfaces vpp bonding vppbond0 vif 38 address 2001:db8:100::2/126
Immediately causes both VLAN subinterfaces to transition to DOWN state:
BondEthernet0 bond 02:fe:3e:39:fa:41 9000 up
BondEthernet0.38 bond 198.51.100.2/30 00:00:00:00:00:00 1500 down
BondEthernet0.30 bond 203.0.113.2/24 00:00:00:00:00:00 1500 down
Log:
May 21 18:01:34 r1 vpp[3037]: clib_c11_violation: s1 NULL
May 21 18:01:34 r1 vpp[3037]: clib_c11_violation: s2 NULL
May 21 18:01:34 r1 vpp[3037]: interface: hw_add_del_mac_address: vnet_hw_interface_add_del_mac_address: Secondary MAC Addresses not supported for >
Additional observations:
BondEthernet0 itself remains UP
All underlying DPDK interfaces remain operational
The issue appears to affect only VLAN subinterfaces on the VPP bonded interface
MAC addresses on subinterfaces are displayed as 00:00:00:00:00:00
VPP logs also report:
Secondary MAC Addresses not supported for interface index 0
This behavior is reproducible and occurs during normal configuration changes such as adding/removing IP addresses from a single VIF.
Environment:
VyOS rolling / 2026.03
VPP dataplane
LACP bond with multiple VLAN subinterfaces
Please let me know if additional debugging information is required.
