VPP/XDP feature help
Hi all,
As VPP & XDP are now included in rolling for some time, I’d like to ask how people are using it. The barebones documentation teases some ~600% increase in throughput, but with little documentation of all the new config options. As 25G home connections are cheaply available in my country, this is very interesting to me, but I’m struggling to get off the ground:
trying to apply on a mlx5 (ConnectX4 - 25Gx2) on VyOS 2025.04.09-0018-rolling:
# show vpp
+nat44 {
+    source {
+        inside-interface eth2
+        outside-interface eth1
+settings {
+    cpu {
+        corelist-workers 1-3
+        main-core 0
+    interface eth1 {
+        driver xdp
+    interface eth2 {
+        driver xdp
+    memory {
makes vyos very unhappy:
# commit
[ vpp ]
WARNING: offload option in eth1 settings is not supported by VPP interfaces. It will be ignored.
WARNING: ring-buffer option in eth1 settings is not supported by VPP interfaces. It will be ignored.
  File "/usr/libexec/vyos/services/vyos-configd", line 146, in run_script
    script.apply(c)
  File "/usr/libexec/vyos//conf_mode/vpp.py", line 655, in apply
    vpp_control = VPPControl(attempts=20, interval=500)
  File "/usr/lib/python3/dist-packages/vyos/vpp/control_vpp.py", line 109, in __init__
    raise VPPIOError(2, 'Cannot connect to VPP API')
vpp_papi.vpp_papi.VPPIOError: [Errno 2] Cannot connect to VPP API
[[vpp]] failed
[[vpp nat44 source]] failed
Commit failed
I also note I cannot install mlx5 dpdk drivers (OFED), due to vyos repos not containing the required packages (automake, dkms, flex, bison, etc…). Maybe this is the issue?
Has anyone been able to test VPP with any network card vendor?
What do you see after this error if you try this
sudo /usr/bin/vpp -c /run/vpp/vpp.conf
Did you try DPDK driver?
Ah - it barfs at empty memory key:
$ sudo /usr/bin/vpp -c /run/vpp/vpp.conf
unknown 'memory' config input ''
Unfortunately totally lacking from documentation.
I will set some default and report back this evening (with dpdk test too)
Delete the empty memory option
Hmm tried again with DPDK config:
+ vpp {
+     interfaces {
+         vxlan vxlan10 {
+             kernel-interface "vpptap10"
+             remote "10.10.10.2"
+             source-address "10.10.10.1"
+             vni "3"
+     kernel-interfaces vpptap10 {
+         address "10.10.10.3/24"
+     settings {
+             vni "3"
+     settings {
+         cpu {
+             corelist-workers "3"
+             corelist-workers "2"
+             main-core "0"
+         interface eth1 {
+             dpdk-options {
+                 num-rx-queues "2"
+                 num-tx-queues "2"
+             driver "dpdk"
+         interface eth2 {
+             dpdk-options {
+                 num-rx-queues "2"
+                 num-tx-queues "2"
+             driver "dpdk"
+         memory {
+             main-heap-page-size "default-hugepage"
+             main-heap-size "4G"
+         statseg {
+             page-size "default-hugepage"
+             size "256M"
and sudo /usr/bin/vpp -c /run/vpp/vpp.conf reports:
dsouthwi@vyos# sudo /usr/bin/vpp -c /run/vpp/vpp.conf
Main heap allocation failure!
when trying with commit-confirm, I get
dsouthwi@vyos# commit-confirm 5
commit-confirm will automatically reload previous config in 5 minutes
unless changes are confirmed.
Proceed ? [Y/n]
Initialized commit-confirm; 5 minutes to confirm before reload
[ vpp ]
    script.apply(c)
[[vpp]] failed
Is this referring to flowtables - eg routing offload? or a driver offload? Message is unclear.
Im unconfidently assuming they’re incompatible with the dataplane and all… but I guess no checks are done as of yet.
I’ve tried to enable tc-flower on my mlx5 device, but apparently that requires mellanox mst/mft drivers, which is difficult (easy in debian)
Something is wrong with memory section
Why not remove it at all during the test?
Try this minimal config
set vpp settings interface eth0 driver 'dpdk'
set vpp settings interface eth1 driver 'dpdk'
set vpp interfaces vxlan vxlan10 remote '192.0.2.2'
set vpp interfaces vxlan vxlan10 source-address '192.0.2.1'
set vpp interfaces vxlan vxlan10 vni '10'
set vpp interfaces loopback lo10 kernel-interface 'vpptun10'
set vpp interfaces bridge br10 member interface eth1
set vpp interfaces bridge br10 member interface vxlan10
set vpp interfaces bridge br10 member interface lo10 bvi
set vpp kernel-interfaces vpptun10 address '100.64.0.1/24'
Hmm, tried this but no love. From your example:
+ vpp {
+     interfaces {
+         bridge br10 {
+             member {
+                 interface eth2 {
+                 interface lo10 {
+                     bvi
+                 interface vxlan10 {
+         loopback lo10 {
+             kernel-interface "vpptun10"
+         vxlan vxlan10 {
+             vni "10"
+     kernel-interfaces vpptun10 {
+         address "10.10.0.10/24"
+     settings {
+         interface eth1 {
+             driver "dpdk"
+         interface eth2 {
+             driver "dpdk"
[ vpp ]
cores spun up as expected, but no connection, and dmesg spits lots of angry things:
[14522.347560] page_pool_release_retry() stalled pool shutdown 1 inflight 14499 sec (hundreds of times)
[18947.547157] IPv4: martian source 85.195.XXX.XXX (my IP) from 0.0.0.0, on dev eth1
[18947.547187] ll header: 00000000: 50 6b 4b 29 7f 7c 00 00 f7 f7 02 56 08 00
[26662.736708] mlx5_core 0000:01:00.1 eth2: Link down
[64267.182723] mlx5_core 0000:01:00.1 eth2: Link up
[76021.529987] mlx5_core 0000:01:00.1 eth2: Link down
[78457.354303] mlx5_core 0000:01:00.1 eth2: Link up[88758.804499] Initializing XFRM netlink socket
[88760.837601] mlx5_core 0000:01:00.0 eth1: Error cqe on cqn 0x22, ci 0x0, qn 0x10be, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88760.838153] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88760.838156] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88760.838159] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88760.838161] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 be 00 00 d8 d2
[88760.838164] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88760.838168] 00000000: 00 00 00 0a 00 10 be 04 00 00 00 08 00 00 00 00
[88760.838170] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
[88760.838173] 00000020: f7 f7 02 56 50 6b 4b 29 7f 7c 08 00 45 00 00 54
[88760.838176] 00000030: 00 00 00 50 00 00 22 00 00 00 00 00 6f 88 40 52
[88760.838190] mlx5_core 0000:01:00.0 eth1: ERR CQE on SQ: 0x10be
[88761.065281] ------------[ cut here ]------------
[88761.065283] WARNING: CPU: 2 PID: 65910 at drivers/iommu/dma-iommu.c:1094 iommu_dma_unmap_page+0x74/0x90
[88761.065289] Modules linked in: xfrm_user xfrm_algo uio_pci_generic uio nf_conntrack_bridge nft_flow_offload nf_flow_table_inet nf_flow_table nft_nat nft_masq af_packet nft_ct nft_chain_nat nf_nat nf_tables nfnetlink_cthelper nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nfnetlink binfmt_misc intel_rapl_common crct10dif_pclmul crc32_pclmul ghash_clmulni_intel sha512_ssse3 sha256_ssse3 sha1_ssse3 aesni_intel virtio_console virtio_balloon crypto_simd cryptd iTCO_wdt pcspkr iTCO_vendor_support button evdev tcp_bbr sch_fq_codel mpls_iptunnel mpls_router ip_tunnel br_netfilter bridge stp llc vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio fuse efi_pstore configfs ip_tables x_tables autofs4 usb_storage ohci_hcd sd_mod squashfs lz4_decompress loop overlay ext4 crc16 mbcache jbd2 nls_cp437 vfat fat efivarfs nls_ascii mlx5_ib ib_uverbs ib_core hid_generic usbhid hid virtio_net net_failover failover ahci virtio_blk libahci libata virtio_pci virtio_pci_legacy_dev scsi_mod virtio_pci_modern_dev crc32c_intel scsi_common
[88761.065341]  mlx5_core virtio ehci_pci virtio_ring i2c_i801 mlxfw pci_hyperv_intf uhci_hcd i2c_smbus lpc_ich ehci_hcd
[88761.065348] CPU: 2 PID: 65910 Comm: vpp_main Not tainted 6.6.79-vyos #1
[88761.065350] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
[88761.065351] RIP: 0010:iommu_dma_unmap_page+0x74/0x90
[88761.065353] Code: 2b 48 3b 28 72 26 48 3b 68 08 73 20 4d 89 f8 44 89 f1 4c 89 ea 48 89 ee 48 89 df 5b 5d 41 5c 41 5d 41 5e 41 5f e9 2c e3 ae ff <0f> 0b 5b 5d 41 5c 41 5d 41 5e 41 5f e9 26 4a 6c 00 66 66 2e 0f 1f
[88761.065354] RSP: 0000:ffff9800c6d0bd18 EFLAGS: 00010246
[88761.065356] RAX: 0000000000000000 RBX: ffff899880f120c0 RCX: 0000000000000000
[88761.065357] RDX: 0000000000000000 RSI: ffff8999828cd000 RDI: 0000000000000000
[88761.065358] RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000001
[88761.065358] R10: ffff9800c2a9b100 R11: ffff9800c2a9b100 R12: 000000006f884052
[88761.065359] R13: 0000000000000050 R14: 0000000000000001 R15: 0000000000000000
[88761.065362] FS:  00007f7fce0e5f40(0000) GS:ffff899befd00000(0000) knlGS:0000000000000000
[88761.065363] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[88761.065364] CR2: 00007f7f84a7dff8 CR3: 00000001e15e2000 CR4: 0000000000750ee0
[88761.065366] PKRU: 55555554
[88761.065366] Call Trace:
[88761.065371]  <TASK>
[88761.065372]  ? iommu_dma_unmap_page+0x74/0x90
[88761.065373]  ? __warn+0x78/0x110
[88761.065378]  ? iommu_dma_unmap_page+0x74/0x90
[88761.065379]  ? report_bug+0x159/0x180
[88761.065383]  ? handle_bug+0x58/0x90
[88761.065385]  ? exc_invalid_op+0x13/0x60
[88761.065387]  ? asm_exc_invalid_op+0x16/0x20
[88761.065391]  ? iommu_dma_unmap_page+0x74/0x90
[88761.065392]  ? iommu_dma_unmap_page+0x29/0x90
[88761.065394]  mlx5e_poll_tx_cq+0x151/0x510 [mlx5_core]
[88761.065433]  mlx5e_napi_poll+0x7d/0x710 [mlx5_core]
[88761.065458]  ? srso_alias_return_thunk+0x5/0xfbef5
[88761.065460]  __napi_poll+0x23/0x1a0
[88761.065463]  net_rx_action+0x141/0x2c0
[88761.065465]  handle_softirqs+0xd2/0x280
[88761.065467]  __irq_exit_rcu+0x68/0x90
[88761.065468]  common_interrupt+0x3c/0xa0
[88761.065471]  asm_common_interrupt+0x22/0x40
[88761.065472] RIP: 0033:0x7f7fcf89b473
[88761.065473] Code: 4c 8b 5c 24 30 48 83 c4 48 eb a1 66 2e 0f 1f 84 00 00 00 00 00 66 90 64 48 8b 14 25 08 00 00 00 48 8b 05 48 fc 01 00 48 39 02 <75> 16 48 8b 07 48 c1 e0 04 48 8b 04 02 48 83 f8 ff 74 05 48 03 47
[88761.065475] RSP: 002b:00007f7f86cc2dd8 EFLAGS: 00000246
[88761.065476] RAX: 0000000000000003 RBX: 00007f7f8e0e5700 RCX: 0000000000000000
[88761.065477] RDX: 00007f7fce0e68e0 RSI: 0000000000000000 RDI: 00007f7fcf87af30
[88761.065477] RBP: 00012224361f9ed0 R08: 0000000000000024 R09: 00000000000008f3
[88761.065478] R10: 0000000000000000 R11: 0000000000000000 R12: 00007f7f8ebbe4c0
[88761.065479] R13: 00007f7f8e0e5700 R14: 00012224361f9ed0 R15: 000055c43980ec40
[88761.065481]  </TASK>
[88761.065481] ---[ end trace 0000000000000000 ]---
[88761.065483] mlx5_core 0000:01:00.0 eth1: Error cqe on cqn 0x22, ci 0x4, qn 0x10be, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88761.065784] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.065785] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.065786] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.065786] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 be 00 00 dc d2
[88761.065787] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88761.065788] 00000000: 00 00 00 0a 00 10 be 04 00 00 00 08 00 00 00 00
[88761.065789] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
[88761.065790] 00000020: f7 f7 02 56 50 6b 4b 29 7f 7c 08 00 45 00 00 28
[88761.065791] 00000030: 00 00 00 24 00 00 22 00 00 00 00 00 6f 53 f0 52
[88761.065807] mlx5_core 0000:01:00.0 eth1: ERR CQE on SQ: 0x10be
[88761.106890] mlx5_core 0000:01:00.0 eth1: Error cqe on cqn 0x1d, ci 0x0, qn 0x10b9, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88761.107189] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.107192] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.107195] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88761.107197] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 b9 00 00 df d2
[88761.107200] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88761.107203] 00000000: 00 00 00 0a 00 10 b9 04 00 00 00 08 00 00 00 00
[88761.107205] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
[88761.107207] 00000020: f7 f7 02 56 50 6b 4b 29 7f 7c 08 00 45 00 00 28
[88761.107210] 00000030: 00 00 00 2a 00 00 22 00 00 00 00 00 6f 53 e0 52
[88761.107224] mlx5_core 0000:01:00.0 eth1: ERR CQE on SQ: 0x10b9
[88762.013802] mlx5_core 0000:01:00.0 defunct_eth1: renamed from eth1
[88763.071279] mlx5_core 0000:01:00.0 defunct_eth1: Link up
[88763.076888] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x18, ci 0x0, qn 0x10c8, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88763.077207] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.077208] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.077209] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.077210] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 c8 00 00 ae d2
[88763.077211] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88763.077212] 00000000: 00 00 00 0a 00 10 c8 04 00 00 00 08 00 00 00 00
[88763.077213] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 33 33
[88763.077214] 00000020: 00 00 00 16 50 6b 4b 29 7f 7c 86 dd 60 00 00 00
[88763.077215] 00000030: 00 00 00 98 00 00 22 00 00 00 00 00 6f 53 a0 14
[88763.082685] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10c8
[88763.083367] tun: Universal TUN/TAP device driver, 1.6
[88763.103292] infiniband mlx5_0: dump_cqe:273:(pid 65950): WC error: 6, Message: memory bind operation error
[88763.103295] cqe_dump: 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.103297] cqe_dump: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.103297] cqe_dump: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.103298] cqe_dump: 00000030: 00 00 00 00 12 00 78 06 25 00 00 93 00 00 f7 d2
[88763.103326] ------------[ cut here ]------------
[88763.103327] WARNING: CPU: 2 PID: 65910 at drivers/infiniband/hw/mlx5/umr.c:333 mlx5r_umr_post_send_wait+0x32e/0x4f0 [mlx5_ib]
[88763.103339] Modules linked in: vhost_net vhost vhost_iotlb tap tun xfrm_user xfrm_algo uio_pci_generic uio nf_conntrack_bridge nft_flow_offload nf_flow_table_inet nf_flow_table nft_nat nft_masq af_packet nft_ct nft_chain_nat nf_nat nf_tables nfnetlink_cthelper nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nfnetlink binfmt_misc intel_rapl_common crct10dif_pclmul crc32_pclmul ghash_clmulni_intel sha512_ssse3 sha256_ssse3 sha1_ssse3 aesni_intel virtio_console virtio_balloon crypto_simd cryptd iTCO_wdt pcspkr iTCO_vendor_support button evdev tcp_bbr sch_fq_codel mpls_iptunnel mpls_router ip_tunnel br_netfilter bridge stp llc vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio fuse efi_pstore configfs ip_tables x_tables autofs4 usb_storage ohci_hcd sd_mod squashfs lz4_decompress loop overlay ext4 crc16 mbcache jbd2 nls_cp437 vfat fat efivarfs nls_ascii mlx5_ib ib_uverbs ib_core hid_generic usbhid hid virtio_net net_failover failover ahci virtio_blk libahci libata virtio_pci virtio_pci_legacy_dev scsi_mod
[88763.103381]  virtio_pci_modern_dev crc32c_intel scsi_common mlx5_core virtio ehci_pci virtio_ring i2c_i801 mlxfw pci_hyperv_intf uhci_hcd i2c_smbus lpc_ich ehci_hcd
[88763.103389] CPU: 2 PID: 65910 Comm: vpp_main Tainted: G        W          6.6.79-vyos #1
[88763.103391] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
[88763.103391] RIP: 0010:mlx5r_umr_post_send_wait+0x32e/0x4f0 [mlx5_ib]
[88763.103398] Code: 48 89 ef e8 34 2c 98 d2 48 8d 7c 24 60 e8 6a 1b 98 d2 44 8b 4c 24 58 45 85 c9 74 6c 41 83 f9 05 0f 84 d8 fd ff ff 48 8b 1c 24 <0f> 0b 65 4c 8b 2c 25 80 df 02 00 4c 8d a3 08 05 00 00 45 8b 85 28
[88763.103400] RSP: 0018:ffff9800c6d0b978 EFLAGS: 00010202
[88763.103401] RAX: 0000000000000001 RBX: ffff899889642000 RCX: 0000000000000000
[88763.103402] RDX: 0000000000000001 RSI: 0000000055555554 RDI: ffff9800c6d0b9e0
[88763.103403] RBP: ffff899889642b28 R08: ffff899befd2f238 R09: 0000000000000006
[88763.103404] R10: 0000000000000001 R11: 0000000000000001 R12: 0000000000000080
[88763.103405] R13: ffff89988d3e6800 R14: ffff899889642b10 R15: 0000000000000000
[88763.103407] FS:  00007f7fce0e5f40(0000) GS:ffff899befd00000(0000) knlGS:0000000000000000
[88763.103408] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[88763.103409] CR2: 0000557e474645c0 CR3: 00000001e15e2000 CR4: 0000000000750ee0
[88763.103411] PKRU: 55555554
[88763.103411] Call Trace:
[88763.103413]  <TASK>
[88763.103414]  ? mlx5r_umr_post_send_wait+0x32e/0x4f0 [mlx5_ib]
[88763.103421]  ? __warn+0x78/0x110
[88763.103425]  ? mlx5r_umr_post_send_wait+0x32e/0x4f0 [mlx5_ib]
[88763.103432]  ? report_bug+0x159/0x180
[88763.103436]  ? handle_bug+0x58/0x90
[88763.103438]  ? exc_invalid_op+0x13/0x60
[88763.103439]  ? asm_exc_invalid_op+0x16/0x20
[88763.103443]  ? mlx5r_umr_post_send_wait+0x32e/0x4f0 [mlx5_ib]
[88763.103449]  ? mlx5r_umr_post_send_wait+0x316/0x4f0 [mlx5_ib]
[88763.103456]  ? __pfx_mlx5r_umr_done+0x10/0x10 [mlx5_ib]
[88763.103462]  mlx5r_umr_update_mr_pas+0x255/0x3c0 [mlx5_ib]
[88763.103470]  ? __pfx_ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0x10/0x10 [ib_uverbs]
[88763.103477]  create_real_mr+0x17c/0x1a0 [mlx5_ib]
[88763.103485]  ? rdma_lookup_get_uobject+0x37/0x180 [ib_uverbs]
[88763.103490]  ? __pfx_ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0x10/0x10 [ib_uverbs]
[88763.103495]  ib_uverbs_reg_mr+0x16e/0x2a0 [ib_uverbs]
[88763.103501]  ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0xbf/0x130 [ib_uverbs]
[88763.103507]  ib_uverbs_cmd_verbs+0xbfa/0xca0 [ib_uverbs]
[88763.103512]  ? srso_alias_return_thunk+0x5/0xfbef5
[88763.103514]  ? __pfx_ib_uverbs_handler_UVERBS_METHOD_INVOKE_WRITE+0x10/0x10 [ib_uverbs]
[88763.103518]  ? srso_alias_return_thunk+0x5/0xfbef5
[88763.103522]  ? srso_alias_return_thunk+0x5/0xfbef5
[88763.103523]  ? blk_finish_plug+0x20/0x40
[88763.103525]  ? srso_alias_return_thunk+0x5/0xfbef5
[88763.103527]  ? do_madvise.part.0+0x561/0xc60
[88763.103530]  ib_uverbs_ioctl+0x9f/0x110 [ib_uverbs]
[88763.103534]  __x64_sys_ioctl+0x8b/0xc0
[88763.103537]  do_syscall_64+0x34/0x80
[88763.103539]  entry_SYSCALL_64_after_hwframe+0x78/0xe2
[88763.103541] RIP: 0033:0x7f7fce334d1b
[88763.103542] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1c 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[88763.103544] RSP: 002b:00007f7f84a7e2d0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[88763.103545] RAX: ffffffffffffffda RBX: 00007f7f84a7e350 RCX: 00007f7fce334d1b
[88763.103546] RDX: 00007f7f84a7e370 RSI: 00000000c0181b01 RDI: 0000000000000013
[88763.103547] RBP: 0000000000000028 R08: 000055c45d130ae0 R09: 00007f7f84a7e388
[88763.103547] R10: 0000000000000000 R11: 0000000000000246 R12: 00007f7f84a7e4b4
[88763.103548] R13: 000000000000000c R14: 00007f7f84a7e4c8 R15: 000055c45d130c20
[88763.103550]  </TASK>
[88763.103550] ---[ end trace 0000000000000000 ]---
[88763.103551] infiniband mlx5_0: mlx5r_umr_post_send_wait:334:(pid 65910): reg umr failed (6). Trying to recover and resubmit the flushed WQEs
[88763.270693] mlx5_core 0000:01:00.1 defunct_eth2: renamed from eth2
[88763.407033] mlx5_core 0000:01:00.1 defunct_eth2: Link up
[88763.917606] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x1d, ci 0x0, qn 0x10cd, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88763.917933] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.917936] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.917939] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88763.917941] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 cd 00 00 ab d2
[88763.917944] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88763.917947] 00000000: 00 00 00 0a 00 10 cd 04 00 00 00 08 00 00 00 00
[88763.917949] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 33 33
[88763.917956] 00000020: 00 00 00 16 50 6b 4b 29 7f 7c 86 dd 60 00 00 00
[88763.917958] 00000030: 00 00 00 84 00 00 22 00 00 00 00 00 6f 4f f0 14
[88763.918276] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10cd
[88764.001391] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x18, ci 0x2, qn 0x10c8, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88764.001701] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.001703] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.001704] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.001704] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 c8 00 00 ac d2
[88764.001705] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88764.001706] 00000000: 00 00 00 0a 00 10 c8 04 00 00 00 08 00 00 00 00
[88764.001707] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 33 33
[88764.001708] 00000020: ff 00 00 12 50 6b 4b 29 7f 7c 86 dd 60 00 00 00
[88764.001708] 00000030: 00 00 00 44 00 00 22 00 00 00 00 00 6f 53 ac 14
[88764.001743] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10c8
[88764.008936] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x1d, ci 0x1, qn 0x10cd, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88764.009245] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.009246] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.009247] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88764.009248] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 cd 00 00 aa d2
[88764.009249] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88764.009250] 00000000: 00 00 00 0a 00 10 cd 04 00 00 00 08 00 00 00 00
[88764.009251] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 33 33
[88764.009251] 00000020: ff 29 7f 7c 50 6b 4b 29 7f 7c 86 dd 60 00 00 00
[88764.009252] 00000030: 00 00 00 44 00 00 22 00 00 00 00 00 6f 4f f5 94
[88764.009278] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10cd
[88768.094171] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x27, ci 0x0, qn 0x10d7, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88768.094492] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88768.094493] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88768.094494] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88768.094495] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 d7 00 00 b1 d2
[88768.094496] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88768.094497] 00000000: 00 00 00 0a 00 10 d7 04 00 00 00 08 00 00 00 00
[88768.094498] 00000010: 00 00 00 00 c0 00 00 00 00 00 00 00 00 12 33 33
[88768.094499] 00000020: 00 01 00 02 50 6b 4b 29 7f 7c 86 dd 60 0b 40 53
[88768.094499] 00000030: 00 00 00 8a 00 00 22 00 00 00 00 00 6f 4f e9 1c
[88768.094509] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10d7
[88768.158701] page_pool_release_retry() stalled pool shutdown 1 inflight 88750 sec
[88782.302244] mlx5_core 0000:01:00.0 defunct_eth1: Error cqe on cqn 0x22, ci 0x0, qn 0x10d2, opcode 0xd, syndrome 0x4, vendor syndrome 0x51
[88782.302561] 00000000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88782.302563] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88782.302564] 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[88782.302564] 00000030: 00 00 00 00 04 00 51 04 0a 00 10 d2 00 00 b4 d2
[88782.302565] WQE DUMP: WQ size 8192 WQ cur size 0, WQE index 0x0, len: 64
[88782.302567] 00000000: 00 00 00 0a 00 10 d2 04 00 00 00 08 00 00 00 00
[88782.302567] 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
[88782.302568] 00000020: f7 f7 02 56 50 6b 4b 29 7f 7c 86 dd 60 00 00 00
[88782.302569] 00000030: 00 00 00 44 00 00 22 00 00 00 00 00 6b ff f0 14
[88782.302593] mlx5_core 0000:01:00.0 defunct_eth1: ERR CQE on SQ: 0x10d2
[88819.483169] page_pool_release_retry() stalled pool shutdown 206 inflight 60 sec
[88820.616111] mlx5_core 0000:01:00.0 defunct_eth1: Failed to get min RX wqes on Channel[1] RQN[0xc0004f] wq cur_sz(0) min_rx_wqes(128)
[88820.616117] mlx5_core 0000:01:00.0 defunct_eth1: RX timeout on channel: 1, ICOSQ: 0x10e7,  RQ: 0xc0004f, CQ: 0x33
[88820.618402] mlx5_core 0000:01:00.0 defunct_eth1: EQ 0x8: Cons = 0x7a31d, irqn = 0x3a
[88820.640398] mlx5_core 0000:01:00.0 defunct_eth1: Failed to get min RX wqes on Channel[2] RQN[0xc00050] wq cur_sz(0) min_rx_wqes(128)
[88820.640406] mlx5_core 0000:01:00.0 defunct_eth1: RX timeout on channel: 2, ICOSQ: 0x10ec,  RQ: 0xc00050, CQ: 0x38
[88820.662083] mlx5_core 0000:01:00.0 defunct_eth1: Failed to get min RX wqes on Channel[3] RQN[0xc00051] wq cur_sz(0) min_rx_wqes(128)
[88820.662090] mlx5_core 0000:01:00.0 defunct_eth1: RX timeout on channel: 3, ICOSQ: 0x10f1,  RQ: 0xc00051, CQ: 0x3d
[88820.668110] mlx5_core 0000:01:00.0: free_4k:279:(pid 65878): page not found
[89121.542290] page_pool_release_retry() stalled pool shutdown 206 inflight 362 sec
[89128.615872] mlx5_core 0000:01:00.0: E-Switch: Unload vfs: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[89128.618823] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[89130.629664] page_pool_release_retry() stalled pool shutdown 1 inflight 89113 sec
[89180.889193] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[89181.104693] mlx5_core 0000:01:00.0: E-Switch: cleanup
[89181.954119] page_pool_release_retry() stalled pool shutdown 206 inflight 422 sec
[89182.231397] mlx5_core 0000:01:00.0: mlx5_cmd_out_err:806:(pid 739): MANAGE_PAGES(0x108) op_mod(0x2) failed, status bad system state(0x4), syndrome (0xe8912), err(-5)
[89182.231787] mlx5_core 0000:01:00.0: reclaim_pages:558:(pid 739): failed reclaiming pages: err -5
[89182.232033] mlx5_core 0000:01:00.0: mlx5_reclaim_root_pages:698:(pid 739): reclaim_pages err (-5) func_id=0x0 ec_func=0x0
[89182.232036] ------------[ cut here ]------------
[89182.232036] FW pages counter is 28674 after reclaiming all pages
[89182.232066] WARNING: CPU: 0 PID: 739 at drivers/net/ethernet/mellanox/mlx5/core/pagealloc.c:730 mlx5_reclaim_startup_pages+0x22a/0x290 [mlx5_core]
[89182.232108] Modules linked in: vhost_net vhost vhost_iotlb tap tun xfrm_user xfrm_algo uio_pci_generic uio nf_conntrack_bridge nft_flow_offload nf_flow_table_inet nf_flow_table nft_nat nft_masq af_packet nft_ct nft_chain_nat nf_nat nf_tables nfnetlink_cthelper nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 nfnetlink binfmt_misc intel_rapl_common crct10dif_pclmul crc32_pclmul ghash_clmulni_intel sha512_ssse3 sha256_ssse3 sha1_ssse3 aesni_intel virtio_console virtio_balloon crypto_simd cryptd iTCO_wdt pcspkr iTCO_vendor_support button evdev tcp_bbr sch_fq_codel mpls_iptunnel mpls_router ip_tunnel br_netfilter bridge stp llc vfio_pci vfio_pci_core irqbypass vfio_iommu_type1 vfio fuse efi_pstore configfs ip_tables x_tables autofs4 usb_storage ohci_hcd sd_mod squashfs lz4_decompress loop overlay ext4 crc16 mbcache jbd2 nls_cp437 vfat fat efivarfs nls_ascii mlx5_ib ib_uverbs ib_core hid_generic usbhid hid virtio_net net_failover failover ahci virtio_blk libahci libata virtio_pci virtio_pci_legacy_dev scsi_mod
[89182.232158]  virtio_pci_modern_dev crc32c_intel scsi_common mlx5_core virtio ehci_pci virtio_ring i2c_i801 mlxfw pci_hyperv_intf uhci_hcd i2c_smbus lpc_ich ehci_hcd
[89182.232167] CPU: 0 PID: 739 Comm: python3 Tainted: G        W          6.6.79-vyos #1
[89182.232169] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org 04/01/2014
[89182.232170] RIP: 0010:mlx5_reclaim_startup_pages+0x22a/0x290 [mlx5_core]
[89182.232193] Code: 05 00 00 e8 c8 8e a2 d2 e9 21 ff ff ff 0f 0b 41 8b b5 b0 07 00 00 85 f6 0f 84 6c ff ff ff 48 c7 c7 c0 b0 77 c0 e8 46 a2 46 d2 <0f> 0b 41 8b b5 b8 07 00 00 85 f6 0f 84 5e ff ff ff 48 c7 c7 f8 b0
[89182.232195] RSP: 0018:ffff9800c184fca0 EFLAGS: 00010286
[89182.232196] RAX: 0000000000000000 RBX: ffff8998811f4928 RCX: 0000000000000027
[89182.232197] RDX: ffff899befc1d4c8 RSI: 0000000000000001 RDI: ffff899befc1d4c0
[89182.232198] RBP: 0000000000000000 R08: 0000000000000000 R09: ffff9800c184fb38
[89182.232199] R10: 0000000000000003 R11: ffffffff93ebab08 R12: 0000000000000000
[89182.232199] R13: ffff8998811f41a0 R14: 0000000000000000 R15: 0000000000001388
[89182.232202] FS:  00007f3b10779040(0000) GS:ffff899befc00000(0000) knlGS:0000000000000000
[89182.232203] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[89182.232204] CR2: 0000558fdcb0ad70 CR3: 000000012b078000 CR4: 0000000000750ef0
[89182.232206] PKRU: 55555554
[89182.232206] Call Trace:
[89182.232209]  <TASK>
[89182.232210]  ? mlx5_reclaim_startup_pages+0x22a/0x290 [mlx5_core]
[89182.232232]  ? __warn+0x78/0x110
[89182.232238]  ? mlx5_reclaim_startup_pages+0x22a/0x290 [mlx5_core]
[89182.232262]  ? report_bug+0x159/0x180
[89182.232265]  ? srso_alias_return_thunk+0x5/0xfbef5
[89182.232267]  ? prb_read_valid+0x12/0x20
[89182.232271]  ? handle_bug+0x58/0x90
[89182.232273]  ? exc_invalid_op+0x13/0x60
[89182.232274]  ? asm_exc_invalid_op+0x16/0x20
[89182.232277]  ? mlx5_reclaim_startup_pages+0x22a/0x290 [mlx5_core]
[89182.232300]  mlx5_function_disable+0x20/0xc0 [mlx5_core]
[89182.232321]  ? srso_alias_return_thunk+0x5/0xfbef5
[89182.232322]  mlx5_uninit_one+0x7e/0xf0 [mlx5_core]
[89182.232344]  remove_one+0x49/0xc0 [mlx5_core]
[89182.232365]  pci_device_remove+0x36/0xa0
[89182.232369]  device_release_driver_internal+0x196/0x200
[89182.232373]  pci_stop_bus_device+0x67/0x90
[89182.232377]  pci_stop_and_remove_bus_device_locked+0x11/0x20
[89182.232378]  remove_store+0x74/0x90
[89182.232381]  kernfs_fop_write_iter+0x103/0x1e0
[89182.232384]  vfs_write+0x1da/0x3a0
[89182.232388]  ksys_write+0x5e/0xe0
[89182.232390]  do_syscall_64+0x34/0x80
[89182.232392]  entry_SYSCALL_64_after_hwframe+0x78/0xe2
[89182.232394] RIP: 0033:0x7f3b1087233f
[89182.232396] Code: 89 54 24 18 48 89 74 24 10 89 7c 24 08 e8 f9 d4 f8 ff 48 8b 54 24 18 48 8b 74 24 10 41 89 c0 8b 7c 24 08 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 31 44 89 c7 48 89 44 24 08 e8 4c d5 f8 ff 48
[89182.232397] RSP: 002b:00007fff1eaae410 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
[89182.232398] RAX: ffffffffffffffda RBX: 0000000000a860d8 RCX: 00007f3b1087233f
[89182.232399] RDX: 0000000000000001 RSI: 0000000026c1b410 RDI: 0000000000000014
[89182.232400] RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000000
[89182.232401] R10: 0000000000000001 R11: 0000000000000293 R12: 00007f3b10778fc0
[89182.232401] R13: 0000000000000014 R14: 0000000000a440c0 R15: 0000000000000000
[89182.232403]  </TASK>
[89182.232404] ---[ end trace 0000000000000000 ]---
Open a bug report on https://vyos.dev/
Describe more details about your hardware there
Following as https://vyos.dev/T7402
