Hi!
Just wanted to check whether I am missing something; but I don’t think OSPF works inside a VRF. OSPFv3 seems to be ok (possibly as you can select interface rather than network). Maybe I am missing some config, but the OSPF works if I remove the VF from the interface.
Thanks,
Joel
