I need to leak route from INET-VRF to default vrf.
for example:
set interfaces ethernet eth0 vif 496 vrf ‘INET-VRF’
set protocols vrf INET-VRF static route 0.0.0.0/0 next-hop 1.1.1.1
set protocols vrf default static route 4.4.4.0/29 next-hop 1.1.1.1 next-hop-vrf ‘INET-VRF’
after that I see in configuration:
show protocols vrf
vrf INET-VRF {
static {
route 0.0.0.0/0 {
next-hop 77.236.229.161 {
vrf default {
static {
route 194.186.83.144/29 {
next-hop-vrf INET-VRF
but in frr configuration INET-VRF is absent:
ip route 4.4.4.0/29 1.1.1.1
vrf INET-VRF
ip route 0.0.0.0/0 1.1.1.1
exit-vrf
I suspect that ip route string should be the floowing:
vrf INET-VRF
ip route 0.0.0.0/0 1.1.1.1 next-hop-vrf INET-VRF
exit-vrf
did I missed something or this is a bug ?
