VRRP and wireguard
Hello folks :slight_smile:
My home virtual VRRP setup works great but i have problem with wireguard in this configuration.
Both nodes have WAN/Internet access but only on VRRP master, wireguard interface needs to be up. I am using wireguard as sts VPN.
My idea is use transition-script with
delete interfaces wireguard wg0 disable or set interfaces wireguard wg0 disable
Can i use configuration commands in script ? Or any better idea ?
Thanks
Yes you can: Command Scripting — VyOS 1.4.x (sagitta) documentation
