I have the below check script that gets the interface of eth0 and if the value exists tests connectivity, otherwise it returns an error.
When I run the script manually, I see “succ” in the checkstate, however when I run “restart vrrp” i see fault in the checkstate file. What could be the issue?
It seems that the output of vtysh is not valid in the environment the check script is run in. if I set eth0gw to “$(echo “127.0.0.1”)” the check script succeeds.
What can I do to get the desired output?
#!/bin/vbash
eth0status="$(/sbin/ethtool eth0 | grep "Link detected: yes)"
if [[ ! -z ${eth0status} ]]; then
eth0gw="$(run show ip route | /usr/bin/awk '/0.0.0.0\/0/&&/eth0/{print $5}' | /bin/sed -e 's/,//g')"
if [[ ! -z ${eth0gw} ]]; then
/bin/ping -I eth0 -c 1 -W 1 ${eth0gw} > /tmp/checkstatus
else
echo "$(date) eth0 up, ping failed"
exit 1
fi
else
echo "$(date) eth0 down"
exit 0
fi
I’ve only recently used vbash in an attempt to troubleshoot. originally eth0gw was set using vtysh -c “sh run ip route” and the script runtime was /bin/bash. However even in your current modification it results in a fault state for VRRP
here is the latest version I made before logging out last night
#!/bin/bash
eth0status="$(/sbin/ethtool eth0 | grep 'Link detected: yes')"
echo "$(date) ${eth0status}" >> /tmp/checkstatus
eth0gw="$(/usr/bin/vtysh -c 'show ip route' | /usr/bin/awk '/0.0.0.0\/0/&&/eth0/{print $5}' | /bin/sed -e 's/,//g')"
echo "$(date) ${eth0gw}" >> /tmp/checkstatus
/bin/ping -I eth0 -c 1 -W 1 ${eth0gw} >> /tmp/checkstatus
else
echo "$(date) eth0 up, ping failed" >> /tmp/checkstatus
exit 1
fi
else
echo "$(date) eth0 down" >> /tmp/checkstatus
#Exit 0 because eth0 down is handled by vrrp transition
exit 0
fi
exit
$ sh ver
Version: VyOS 1.2-rolling-201911180217
Built by: autobuild@vyos.net
Built on: Mon 18 Nov 2019 02:17 UTC
Build UUID: 1b67d568-983a-4200-beb4-2732a4d7879b
Build Commit ID: e7a834c040cbd9
Architecture: x86_64
Boot via: installed image
System type: VMware guest
Hardware vendor: VMware, Inc.
Hardware model: VMware7,1
Hardware S/N: VMware-42 2a 01 58 71 99 0b c5-a4 22 60 63 a3 48 d6 f4
Hardware UUID: 58012a42-9971-c50b-a422-6063a348d6f4
When I redirect stderr from vtysh to a file I see this:
cat /tmp/vty
% Can't open configuration file /etc/frr/vtysh.conf due to 'Permission denied'.
Exiting: failed to connect to any daemons.
frr documentation says that members of the frrvtygroup should have read access, keepalived_script user which runs the check script is a member of the group.
Permissions on the file seem fine -rw-r----- 1 root frrvty 32 Nov 3 14:57 vtysh.conf
And setting all users permission to read results in this error: Exiting: failed to connect to any daemons.
if I log into keepalived_script with sudo su - keepalived_script -s /bin/bash
I can run the vtysh command successfully, it just seems to be the scripted environment that is missing out on running vtysh.
I was able to get the script to work by adding keepalived_script to the sudoers file with NOPASSWD and use an init script to call the below script with sudo, however this isn’t within the normal vyos config and won’t persist across an upgrade.
Is this something that can be a resolvable bug report?
Here is the latest version of the script:
#!/bin/bash
echo "$(date) ==== Starting check script" >> /tmp/checkstatus
echo "$(date) - eth0status: ${eth0status}" >> /tmp/checkstatus
/usr/bin/vtysh -c 'show ip route' &> /tmp/vty
eth0gw="$(/usr/bin/vtysh -c 'show ip route' | grep -Po '^.*0\.0\.0\.0\/0.*via \K[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}(?=, eth0)')"
echo "$(date) - eth0gw: $eth0gw" >> /tmp/checkstatus
if [[ ! -z $eth0gw ]]; then
/bin/ping -I eth0 -c 1 -W 1 $eth0gw >> /tmp/checkstatus
else
exit 1
fi
else
exit 0
fi
@ACiD_GRiM FYI I configured VRRP with your script and all works without any modifications.
vyos@R1# tail -n 9 /tmp/checkstatus
Wed Dec 18 09:45:08 UTC 2019 ==== Starting check script
Wed Dec 18 09:45:08 UTC 2019 - eth0status: Link detected: yes
Wed Dec 18 09:45:08 UTC 2019 - eth0gw: 10.0.0.2
PING 10.0.0.2 (10.0.0.2) from 10.0.0.1 eth0: 56(84) bytes of data.
64 bytes from 10.0.0.2: icmp_seq=1 ttl=64 time=1.93 ms
--- 10.0.0.2 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 1.936/1.936/1.936/0.000 ms
vyos@R1# run show vrrp
Name Interface VRID State Last Transition
group1 eth0 1 MASTER 4m38s
vyos@R1# run show version | match Version
Version: VyOS 1.2-rolling-201912170217
But I’m not sure about your ping command in script, may be better use
I will update to the same build you’ve referenced tonight
Thanks for the script suggestion, I will make the change
edit:
I actually just made the change and still have the same problem. I’m only able to run the script if I run it as sudo, AND keepalived_script user is in sudoers file with NOPASSWD
This is an issue on both routers that were individually configured
I do see that there are improvements in the latest version with Keepalived, such as all vrrp groups in a sync group change state to backup/FAULT when the wangw state changes
I’ll also note an issue I’m having where the transition scripts don’t execute, but not the specific issue I’m reporting here.
Here’s my config:
router 1:
set high-availability vrrp group dmz_gateway advertise-interval ‘1’
set high-availability vrrp group dmz_gateway authentication password ‘mCD!343’
set high-availability vrrp group dmz_gateway authentication type ‘ah’
set high-availability vrrp group dmz_gateway hello-source-address ‘10.255.255.234’
set high-availability vrrp group dmz_gateway interface ‘eth2’
set high-availability vrrp group dmz_gateway preempt-delay ‘10’
set high-availability vrrp group dmz_gateway priority ‘200’
set high-availability vrrp group dmz_gateway virtual-address ‘172.16.0.1/24’
set high-availability vrrp group dmz_gateway vrid ‘2’
set high-availability vrrp group v6_dmz_gateway advertise-interval ‘1’
set high-availability vrrp group v6_dmz_gateway authentication password 'mCD!343’
set high-availability vrrp group v6_dmz_gateway authentication type ‘ah’
set high-availability vrrp group v6_dmz_gateway hello-source-address ‘fd00:f9a8:9a7e:3::234’
set high-availability vrrp group v6_dmz_gateway interface ‘eth2’
set high-availability vrrp group v6_dmz_gateway preempt-delay ‘10’
set high-availability vrrp group v6_dmz_gateway priority ‘200’
set high-availability vrrp group v6_dmz_gateway virtual-address ‘fe80::f345/128’
set high-availability vrrp group v6_dmz_gateway virtual-address ‘fd00:f9a8:172:16::1/64’
set high-availability vrrp group v6_dmz_gateway vrid ‘3’
set high-availability vrrp group wan_gateway advertise-interval ‘1’
set high-availability vrrp group wan_gateway authentication password ‘m*CD!343’
set high-availability vrrp group wan_gateway authentication type ‘ah’
set high-availability vrrp group wan_gateway health-check failure-count ‘3’
set high-availability vrrp group wan_gateway health-check interval ‘2’
set high-availability vrrp group wan_gateway health-check script ‘/usr/bin/sudo /config/scripts/vrrp/wan_gateway-check.sh’
set high-availability vrrp group wan_gateway hello-source-address ‘fd00:f9a8:feed:beef::1’
set high-availability vrrp group wan_gateway interface ‘eth3’
set high-availability vrrp group wan_gateway preempt-delay ‘10’
set high-availability vrrp group wan_gateway priority ‘200’
set high-availability vrrp group wan_gateway transition-script backup ‘/config/scripts/vrrp/wan_gateway-fail.sh’
set high-availability vrrp group wan_gateway transition-script master ‘/config/scripts/vrrp/wan_gateway-master.sh’
set high-availability vrrp group wan_gateway virtual-address ‘fe80::888/128’
set high-availability vrrp group wan_gateway vrid ‘1’
set high-availability vrrp sync-group wangw member ‘wan_gateway’
set high-availability vrrp sync-group wangw member ‘dmz_gateway’
set high-availability vrrp sync-group wangw member ‘v6_dmz_gateway’
set service conntrack-sync failover-mechanism vrrp sync-group ‘wangw’
router 2:
set high-availability vrrp group dmz_gateway hello-source-address ‘10.255.255.233’
set high-availability vrrp group v6_dmz_gateway hello-source-address ‘fd00:f9a8:9a7e:3::233’
set high-availability vrrp group wan_gateway hello-source-address ‘fd00:f9a8:feed:beef::2’
set high-availability vrrp group wan_gateway preempt-delay ‘3’
Wed Dec 18 18:35:58 MST 2019 test
Wed Dec 18 18:36:00 MST 2019 test
Wed Dec 18 18:36:02 MST 2019 test
Wed Dec 18 18:36:04 MST 2019 test
Wed Dec 18 18:36:06 MST 2019 test
set high-availability vrrp group group1 health-check script '/config/scripts/vrrp.sh'
set high-availability vrrp group group1 interface 'eth0'
set high-availability vrrp group group1 virtual-address '10.0.0.254/24'
set high-availability vrrp group group1 vrid '1'
vyos@R1# cat /config/scripts/vrrp.sh
#!/bin/bash
echo "$(date) test" >> /tmp/checkvtysh
/usr/bin/vtysh -c "show ip route" >> /tmp/checkvtysh 2>&1
Version: VyOS 1.3-rolling-201912190503
Built on: Thu 19 Dec 2019 05:03 UTC
vyos@R1# sudo cat /tmp/checkvtysh
Thu 19 Dec 2019 06:43:53 PM UTC test
F - PBR, f - OpenFabric,
> - selected route, * - FIB route, q - queued route, r - rejected route
S>* 0.0.0.0/0 [1/0] via 10.0.0.2, eth0, 11:02:52
S 0.0.0.0/0 [210/0] via 192.168.0.1, eth1, 11:03:09
C>* 10.0.0.0/24 is directly connected, eth0, 11:03:06
C>* 172.16.0.0/24 is directly connected, vti0, 11:02:44
C>* 192.168.0.0/24 is directly connected, eth1, 11:03:11
