I’m are currently testing VyOS as our solution for virtualized firewalls and we are quite happy with it.
But there is one problem i can’t solve. When I use the VRRP Transition Script function to change the configuration, no manual changes are possible afterwards.
The setup is pretty basic:
high-availability {
vrrp {
group test {
address 172.23.254.1/24
interface eth0.80
transition-script {
backup /config/scripts/vrrp_ospd_down.sh
fault /config/scripts/vrrp_ospd_down.sh
master /config/scripts/vrrp_ospd_up.sh
stop /config/scripts/vrrp_ospd_down.sh
vrid 80
For testing purposes, I change a random value of the config with my scripts:
#!/bin/vbash
configure
set system domain-name up.test.local
commit
exit
The result is the same in all cases. The scripts are executed und the value is changed, bit when I try to change something manually afterwards, I receive the following error message:
vyos@vyos1# set system domain-name test.local
Set failed
I know this behaviour is described in the Command Scripting documentation, but since I execute the script via the transition-script option, I don’t know how to call the scripts the proper way. What am I missing?
Greetings
