I’ve tried VRRP and zone zone-based firewall without any result; after setting up zone-based firewall the vrrp break immediately. Although the zones permitted without restriction, the vrrp interfaces can’t see each other.
Are you allowing the ips you assigned to each interface through your firewall?
set interfaces ethernet eth0 address ‘192.168.20.1/24’
set interfaces ethernet eth1 address ‘192.168.21.1/24’
set firewall name WAN_LOCAL rule 12 action ‘accept’
set firewall name WAN_LOCAL rule 12 description ‘Allow vrrp’
set firewall name WAN_LOCAL rule 12 log ‘disable’
set firewall name WAN_LOCAL rule 12 source address ‘192.168.20.2’
set firewall name WAN_LOCAL rule 13 action ‘accept’
set firewall name WAN_LOCAL rule 13 description ‘Allow vrrp’
set firewall name WAN_LOCAL rule 13 log ‘disable’
set firewall name WAN_LOCAL rule 13 source address ‘192.168.21.2’
set firewall name WAN_IN rule 12 action ‘accept’
set firewall name WAN_IN rule 12 description ‘Allow vrrp’
set firewall name WAN_IN rule 12 log ‘disable’
set firewall name WAN_IN rule 12 source address ‘192.168.20.2’
set firewall name WAN_IN rule 13 action ‘accept’
set firewall name WAN_IN rule 13 description ‘Allow vrrp’
set firewall name WAN_IN rule 13 log ‘disable’
set firewall name WAN_IN rule 13 source address ‘192.168.21.2’
set interfaces ethernet eth0 firewall in name WAN_IN
set interfaces ethernet eth0 firewall local name WAN_LOCAL
