VRRPv3 for IPv4?
This command below isn’t a valid when I’m trying to do version 3
set high-availability vrrp global-parameters version 2|3
Reference link is High availability — VyOS 1.4.x (sagitta) documentation
My show version is:
Version: VyOS 1.4-rolling-202306180317
Release train: current
Built by: [email protected]
Built on: Sun 18 Jun 2023 03:17 UTC
Build UUID: 579984fc-40a6-40d7-93b1-2afacdb4919f
Build commit ID: deb4cb7f4d4b3f
Any idea?
Are you typing it directly as written, or something like this?:
set high-availability vrrp global-parameters version 3
yep I am
netops@#:~$ configure
netops@#
netops@# display version
Invalid command: [display]
netops@# run show version
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Dell Inc.
Hardware model: PowerEdge R320
Hardware S/N: 8GCGH32
Hardware UUID: 4c4c4544-0047-4310-8047-b8c04f483332
netops@# set high-availability vrrp global-parameters
Possible completions:
garp Gratuitous ARP parameters
startup-delay Time VRRP startup process (in seconds)
netops@# set high-availability vrrp global-parameter version 3
Configuration path: high-availability vrrp global-parameters [version] is not valid
Set failed
That got fixed in commit d2540ac4c6fc on July 19 2023 so you would have to use a later version of VyOS 1.4.
