VXLAN Gateway VyOS 1.4
I need to know if the VyOS support VXLAN Gateway, for example, on RFC 7348
“One deployment scenario is where the tunnel termination point is a
physical server that understands VXLAN. An alternate scenario is
where nodes on a VXLAN overlay network need to communicate with nodes
on legacy networks that could be VLAN based. These nodes may be
physical nodes or virtual machines. To enable this communication, a
network can include VXLAN gateways (see Figure 4 below with a switch
acting as a VXLAN gateway) that forward traffic between VXLAN and
non-VXLAN environments.”
you can configure VyOS to bridge VXLAN encapsulated traffic to the real world using a standard bridge interfave connecting vxlan0 and eth0
Hi c-po,
Thanks for your reply. I tried to configure the bridge VXLAN, but it was not work, follow my configuration. Using monitor traffic, I see traffic incoming interface eth7 with tagged 254, but the VyOS could not forward the packet through vxlan254
VTEP with non-vxlan host with tagged vlan 254
bridge br254 {
enable-vlan
member {
interface eth7 {
allowed-vlan 254
interface vxlan254 {
allowed-vlan 254
vxlan vxlan254 {
parameters {
nolearning
port 4789
source-address 172.29.0.1
vni 254
VTEP with untagged interface
bridge br254 {
enable-vlan
member {
interface eth2 {
native-vlan 254
allowed-vlan 254
vxlan vxlan254 {
    parameters {
        nolearning
    port 4789
    source-address 172.29.0.3
    vni 254
You are missing vif 254 on your br254 device. Seems you are mixing bridge and vlan aware bridge syntax
