This is probably a stupid question, but how do you enter the remote tunnel end for vxlan?
I checked 510 Software Group, but the following command seems to have been removed.
set interfaces vxlan TXT<vxlann> remote IPV4
Which Vyos version?
Latest one, 1.1.5. I’m thinking that they removed unicast peers, which honestly doesn’t surprise me that much…
1.1.5 is helium branch. set interfaces vxlan TXT remote IPV4 was added in the lithium branch on 2014-12-19. You might try the nightly lithium build at http://dev.packages.vyos.net/iso/ to see if it works for you.
