Hi, I’m developing a tool intended to be run on VyOS devices, and as such I’ve delved into op-mode definitions.
I’ve got it mostly working by reading existing defintions, but I’m stuck on one aspect of the <completionHelp> tag.
I’d like to complete on local file paths, specifically targetting readable files.
Commands such as show file uses the <imagePath> tag which seems to be unavailable for <tagNode> (I just get errors while compiling the definitions that it doesn’t match the schema). Not that I’d actually want to use <imagePath> as it’s beyond the scope of this node type’s targeting.
If there is an easy way to use local file paths as <completionHelp>, like bash does for executables like cat, please let me know.
You probably already figured this out, but this was recommended when I was creating a topic recently and figured I’d give an answer so it’ll be available for anyone that finds this later.
You can use the <script> tag to call a script that you put inside of /src/completion/
You would call it with something like this (look at the ‘test123’ tagNode):
<?xml version="1.0" ?>
<interfaceDefinition>
<node name="connect">
<children>
<tagNode name="container">
<properties>
<help>Attach to a running container</help>
<completionHelp>
<path>container name</path>
</completionHelp>
</properties>
<command>sudo podman exec --interactive --tty "$3" /bin/sh</command>
<children>
<tagNode name="test123">
<properties>
<help>This is just a test command</help>
<completionHelp>
<script>${vyos_completion_dir}/list_test123.sh</script>
</completionHelp>
</properties>
<command>ifconfig</command>
</tagNode>
</children>
</tagNode>
</children>
</node>
</interfaceDefinition>
You can create a simple shell script, or if you need something a little more complex, you can also call a python script.
