VyCenter Alpha Stage Announcement - VyOS Web Interface
Hi guys,
I’m developing a frontend in early stages. Any help / comments will be welcome!
VyOS frontend made in Python / Django using VyOS new 1.3 API server
It will work with a single VyoS server or to multiple VyOS servers, so datacenters which do not want share same firewall to different customers will not need to install several vycenter to each customer. That’s why the name vycenter.
features
in alpha stage we’re going to provide just essential device config, interfaces and firewall, as proof of concencept, as well config module basic cruds (users, groups and vyOS Servers)
interfaces module
  • list interfaces - alpha
  • show interface - alpha
  • unset/set firewall interface - todo
  • change interface parameters - todo
firewall module
  • basic firewall rules creation proof of concept - done
  • basic list firewall rules - done
  • basic add firewall rules - done
  • basic edit firewall rules - done
  • basic firewall create - done
  • change firewall rules order - todo
  • delete firewall rules - todo
other modules - todo
  • ospf
  • bgp
  • ipsec
  • openvpn
  • reports (maybe collecting using snmp)
  • ssh management
  • system login managament
  • nat
  • dhcp servers
  • static routes
config module
  • vycenter users crud - todo
  • vycenter groups crud - todo
  • vyos instance using database - done
  • full vyos instances crud - todo
  • add new VyoS instances test connection while adding - todo
  • add new VyoS instances test connection all servers crontab - todo
  • associate groups to VyOS instances
dockerhub
latest vycenter is being autobuilt at dockerhub
docker pull robertoberto/vycenter
docker composer
Right now we are using db.sqlite3, but I used composer so we can change to mySQL if needed.
docker-compose build
docker-compose  up
manual install instructions
setup virtual env and pip requirements
virtualenv env
source env/bin/activate
pip3 install -r requirements.txt
setup initial database
cd vycenter
python3 manage.py migrate
run webserver
python3 manage.py runserver
access webpage
setup vyos new instance
  • click on Add new instance
  • configure vyos services like explained at docs
  • click on List Instances
  • click on Test Connection
Current README:
vycenter
features
interfaces module
firewall module
  • ospf
  • bgp
  • ipsec
  • openvpn
  • ssh management
  • nat
  • dhcp servers
  • static routes
config module
dockerhub
docker composer
docker-compose  up
virtualenv env
cd vycenter
run webserver
  • configure vyos services like explained in docs
Thanks @robertoberto!
i pinned topic so people can see it more often
(post deleted by author)
  • 20.05.01 - version created to start project framework, organize permission systems and concept test with some firewall and interface functions and statics routes released
please test and give me feedbacks thanks :slight_smile:
put some screenshots in first post to capture more attention
@syncer I cannot edit, on edit icon I can only see history
List VyOS Instances
List Firewall
This looks very interesting! If I understand this correctly, you will be able to create firewall rules, or other configuration snippets, that will be able to push to multiple devices?
For instance in a datacenter where multiple vyos routers share the same firewall groups and rules.
Yes, that’s right. Our users cases will be:
  • datacenter which want to offer Firewall to multiple customers
  • individual installations are supported too and are not harder to implement than multi VyOS instances
We think about ran VyControl inside VyOS or directly as Python django runserver or inside a Docker if we add Docker function inside VyOS for whom want to enable
new screenshoot
VyControl alpha released 20.05.02.1000 - working firewall without zones
  • check at github
  • subscribe announce list at our homepage
VyControl: VyOS Web Frontend
VyControl is a single frontend interface to manage a single or multiple VyoS servers. Only download VyOS Rolling Release, since VyControl needs the latest VyOS API.
Still in 2020, the most important functionalities that until then were only possible through CLI (command line interface), will be possible through a friendly and web interface developed in Django / Python.
Standalone VyoS installations can now have a control panel.
Datacenter installations with multiple VyoS will be able to offer their customers (with users, groups and granular control) firewall as a service
VyControl 20.05.10 - released
Release Description:
Full zone based firewall features.
If managing multiple VyOS instances/routers, it’s becoming somekind of “SDN controller”?
This is a really interesting project. Looking into code, it seems to use django (which is fine) and allow management by hand for instances.
This is nice for smaller environments. Are there thoughts about also allow management of “many” vyos instances in an automatic way?
This looks nice :slight_smile:
I was looking for a firewall that could be easily managed, especially for the SMB market. This project could help bring “managed firewall services” to VyOS big time :slight_smile:
Yes, that’s idea. You can manage several VyOS instances using VyControl.
If you are a Datacenter, your internal team can use VyControl to manage your customers. Or you can give public access to your customers, so they can directly manage their Firewall using VyControl.
Network between VyControl and VyOS intances can be a private VLAN, so users will not need to have public SSH access to VyOS instances anymore.
