I notice an issue with the Python code for vymgmt. If you run the run_conf_mode_command() on a command such as “load”, and then commit the changes e.g. vyos.commit(), it will give an error that there were no configuration changes to commit.
I have fixed this in the code of router.py as follows (line added in bold):
def run_conf_mode_command(self, command):
“”" Executes a VyOS configuration command
:param command: VyOS configuration command
:returns: Command output
:raises: VyOSError
if not self.__conf_mode:
raise VyOSError("Cannot execute configuration mode commands outside of configuration mode")
else:
**self.__session_modified = True**
return self.__execute_command(command)
