Hello All,
I am new to VYOS.
Trying to set up site to site tunnels between multiple locations (mesh) and also L2TP VPN server on all the vyos routers for the remote users to dial into the network.
Site-to-site works fine but not the VPN for the remote users.
If I take out the site to site config then VPN works. Users can dial-in. I am not able to make both site-to-site tunnels and l2tp/ipsec vpn work at the same time.
Any help is appreciated.
Following is my network diagram and the configuration (Site A )
address 1.2.3.4/24
duplex auto
smp_affinity auto
speed auto
address 10.10.1.1/24
duplex auto
smp_affinity auto
speed auto
ethernet eth2 {
duplex auto
smp_affinity auto
speed auto
ethernet eth3 {
duplex auto
smp_affinity auto
speed auto
loopback lo {
vti vti0 {
address 172.16.10.1/30
description "VTI between Site A and Site B"
vti vti1 {
address 172.16.20.1/30
description "VTI between Site A and Site C"
nat {
rule 100 {
outbound-interface eth0
translation {
address masquerade
protocols {
static {
interface-route 10.10.2.0/24 {
next-hop-interface vti0 {
interface-route 10.10.5.0/24 {
next-hop-interface vti1 {
interface-route 10.10.6.0/24 {
interface-route 10.20.0.0/16 {
service {
dhcp-server {
disabled false
shared-network-name Site-A-pool {
authoritative enable
subnet 10.10.1.0/24 {
default-router 10.10.1.1
dns-server 10.10.1.1
lease 86400
start 10.10.1.100 {
stop 10.10.1.199
dns {
forwarding {
cache-size 150
listen-on eth1
name-server 8.8.8.8
name-server 8.8.4.4
ssh {
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
gateway-address 1.2.3.1
host-name vyos-site-a
login {
user vyos {
authentication {
encrypted-password XXXXXXXX
level admin
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
package {
auto-sync 1
repository community {
components main
distribution helium
password ""
username ""
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
vpn {
ipsec {
esp-group ESP-Default {
compression disable
lifetime 3600
mode tunnel
pfs dh-group16
proposal 1 {
encryption aes256
hash sha256
ike-group IKE-Default {
dead-peer-detection {
action clear
interval 30
timeout 90
ikev2-reauth no
key-exchange ikev1
lifetime 86400
proposal 1 {
dh-group 16
encryption aes256
hash sha256
ipsec-interfaces {
interface eth0
logging {
log-modes all
nat-networks {
allowed-network 0.0.0.0/0 {
nat-traversal enable
site-to-site {
peer 1.2.3.5 {
authentication {
id 1.2.3.4
mode pre-shared-secret
pre-shared-secret XXXXXX
connection-type initiate
default-esp-group ESP-Default
ikev2-reauth inherit
local-address 1.2.3.4
vti {
bind vti0
peer 1.2.3.6 {
authentication {
id 1.2.3.4
pre-shared-secret XXXXXXX
vti {
bind vti1
l2tp {
remote-access {
authentication {
local-users {
username test {
password xxxxx
mode local
client-ip-pool {
start 10.10.4.1
stop 10.10.4.255
dns-servers {
server-1 8.8.8.8
server-2 8.8.4.4
ipsec-settings {
authentication {
ike-lifetime 3600
outside-address 1.2.3.4
/* Warning: Do not remove the following line. */
/* === vyatta-config-version: "cluster@1:config-management@1:conntrack-sync@1:conntrack@1:cron@1:dhcp-relay@1:dhcp-server@4:firewall@5:ipsec@4:nat@4:qos@1:quagga@2:system@6:vrrp@1:wanloadbalance@3:webgui@1:webproxy@1:zone-policy@1" === */
/* Release version: VyOS 1.1.8 */
Thanks
