Vyos 1.3.1 - Changing a BGP neighbor's peer-group errors and breaks remote AS
I ran into a bizarre issue when trying to change a neighbor’s peer group that resulted in errors + making FRR think that the neighbor had no remote-as defined. The neighbor was set to shutdown before proceeding with any of these changes. I ended up having to reboot the router in order to get that neighbor’s session back up.
First, I verified the neighbors sessions were shutdown. I then proceeded to set the peer-group to a different peer-group (downstream) from what it was previously (ix).
The following error was displayed, however the changes seemed to apply and was comitted.
% Cannot change the peer-group. Deconfigure first
Error configuring routing subsystem.  See log for more detailed information
My interpretation of this was that the peer-group needed to be removed first, so I proceeded to remove the peer-group entirely from this neighbor. Same message.
% Specify remote-as or peer-group commands first
I then re-applied the downstream peer-group, ignored the error message and turned the neighbors session back up by removing “shutdown” on the neighbor. The session failed to establish as it looks like FRR had a remote-as of 0 even though it was defined in the config.
My questions are as follows:
  1. Do I need to entirely remove a neighbor, commit, then add the neighbor back to change a peer-group? Is it not possible to change a peer-group on a neighbor without deconfiguring the entire neighbor?
  2. Why did this cause the remote-as to disappear from FRR even though it was never modified in the config?
Any insight is greatly appreciated!
Full output below:
[email protected]:~$ show bgp summary
IPv4 Unicast Summary:
BGP router identifier 23.138.8.1, local AS number 951 vrf-id 0
BGP table version 2399391
RIB entries 1672722, using 306 MiB of memory
Peers 16, using 341 KiB of memory
Peer groups 4, using 256 bytes of memory
Neighbor          V         AS   MsgRcvd   MsgSent   TblVer  InQ OutQ  Up/Down State/PfxRcd   PfxSnt
23.138.8.22       4        950      1998    467088        0    0    0 1d09h14m            1   910384
2602:fb51:1:2::22 4        950      2000   1088412        0    0    0 1d09h14m NoNeg
206.83.43.9       4         42      2211      2001        0    0    0 1d09h15m           48        2
206.83.43.10      4       3856      1999      2002        0    0    0 1d09h15m            1        2
206.83.43.30      4       6939     59368      2001        0    0    0 1d09h15m       137172        2
206.83.43.46      4     394414     10279      2005        0    0    0 00:03:16 Idle (Admin)        0
2001:504:9b::9    4         42      2205      2004        0    0    0 1d09h15m NoNeg
2001:504:9b::10   4       3856      1999      2005        0    0    0 1d09h15m NoNeg
2001:504:9b::46   4     394414     10049      2005        0    0    0 00:03:16 Idle (Admin)        0
206.83.43.1       4     397806    149110      2002        0    0    0 1d09h15m        98563        2
206.83.43.2       4     397806    149089      2008        0    0    0 1d09h15m        98821        2
2001:504:9b::1    4     397806    625673      2004        0   32    0 1d09h15m NoNeg
2001:504:9b::2    4     397806    625809      2020        0   31    0 1d09h15m NoNeg
192.190.136.105   4      62943    508655      3997        0   24    0 1d09h15m       910277        2
2001:504:9b::30   4       6939    856934      2001        0  164    0 1d09h15m NoNeg
2604:2980:f00::5  4      62943    255872      3997        0   10    0 1d09h15m NoNeg
Total number of neighbors 16
IPv6 Unicast Summary:
BGP table version 2062041
RIB entries 289531, using 53 MiB of memory
23.138.8.22       4        950      1998    467088        0    0    0 1d09h14m NoNeg
2602:fb51:1:2::22 4        950      2000   1088412        0    0    0 1d09h14m            1   150298
206.83.43.9       4         42      2211      2001        0    0    0 1d09h15m NoNeg
206.83.43.10      4       3856      1999      2002        0    0    0 1d09h15m NoNeg
206.83.43.30      4       6939     59368      2001        0    0    0 1d09h15m NoNeg
2001:504:9b::9    4         42      2205      2004        0    0    0 1d09h15m           23        2
2001:504:9b::10   4       3856      1999      2005        0    0    0 1d09h15m            1        2
206.83.43.1       4     397806    149110      2002        0    0    0 1d09h15m NoNeg
206.83.43.2       4     397806    149089      2008        0    0    0 1d09h15m NoNeg
2001:504:9b::1    4     397806    625673      2004        0   32    0 1d09h15m        40351        2
2001:504:9b::2    4     397806    625809      2020        0   31    0 1d09h15m        40424        2
192.190.136.105   4      62943    508655      3997        0   24    0 1d09h15m NoNeg
2001:504:9b::30   4       6939    856934      2001        0  164    0 1d09h15m       148485        2
2604:2980:f00::5  4      62943    255872      3997        0   10    0 1d09h15m       150272        2
[email protected]# set protocols bgp 951 neighbor 206.83.43.46 peer-group downstream
[email protected]# set protocols bgp 951 neighbor 2001:504:9b::46 peer-group downstream
[email protected]# commit
[ protocols bgp 951 ]
[email protected]# delete protocols bgp 951 neighbor 206.83.43.46 peer-group
[email protected]# delete protocols bgp 951 neighbor 2001:504:9b::46 peer-group
BGP table version 2405363
RIB entries 1672339, using 306 MiB of memory
23.138.8.22       4        950      2019    469012        0    0    0 1d09h35m            1   910173
206.83.43.46      4          0         1         7        0    0    0    never       Active        0
2001:504:9b::46   4          0         0         3        0    0    0    never       Active        0
2602:fb51:1:2::22 4        950      2021   1093257        0    0    0 1d09h35m NoNeg
206.83.43.9       4         42      2235      2023        0    0    0 1d09h37m           48        2
206.83.43.10      4       3856      2021      2024        0    0    0 1d09h37m            1        2
206.83.43.30      4       6939     59698      2023        0    0    0 1d09h37m       137066        2
2001:504:9b::9    4         42      2229      2026        0    0    0 1d09h37m NoNeg
2001:504:9b::10   4       3856      2021      2027        0    0    0 1d09h37m NoNeg
206.83.43.1       4     397806    149453      2024        0    0    0 1d09h37m        98454        2
206.83.43.2       4     397806    149442      2032        0    0    0 1d09h37m        98711        2
2001:504:9b::1    4     397806    627062      2026        0    0    0 1d09h37m NoNeg
2001:504:9b::2    4     397806    627198      2042        0    0    0 1d09h37m NoNeg
192.190.136.105   4      62943    510423      4040        0    0    0 1d09h37m       910075        2
2001:504:9b::30   4       6939    861693      2023        0    0    0 1d09h37m NoNeg
2604:2980:f00::5  4      62943    257511      4040        0    0    0 1d09h37m NoNeg
BGP table version 2070912
RIB entries 289544, using 53 MiB of memory
23.138.8.22       4        950      2019    469012        0    0    0 1d09h35m NoNeg
2602:fb51:1:2::22 4        950      2021   1093257        0    0    0 1d09h35m            1   150307
206.83.43.9       4         42      2235      2023        0    0    0 1d09h37m NoNeg
206.83.43.10      4       3856      2021      2024        0    0    0 1d09h37m NoNeg
206.83.43.30      4       6939     59698      2023        0    0    0 1d09h37m NoNeg
2001:504:9b::9    4         42      2229      2026        0    0    0 1d09h37m           23        2
2001:504:9b::10   4       3856      2021      2027        0    0    0 1d09h37m            1        2
206.83.43.1       4     397806    149453      2024        0    0    0 1d09h37m NoNeg
206.83.43.2       4     397806    149442      2032        0    0    0 1d09h37m NoNeg
2001:504:9b::1    4     397806    627062      2026        0    0    0 1d09h37m        40344        2
2001:504:9b::2    4     397806    627198      2042        0    0    0 1d09h37m        40416        2
192.190.136.105   4      62943    510423      4040        0    0    0 1d09h37m NoNeg
2001:504:9b::30   4       6939    861693      2023        0    0    0 1d09h37m       148494        2
2604:2980:f00::5  4      62943    257511      4040        0    0    0 1d09h37m       150282        2
[email protected]# show protocols bgp 951 neighbor 206
206.83.43.1   206.83.43.10  206.83.43.2   206.83.43.30  206.83.43.46  206.83.43.9
[email protected]# show protocols bgp 951 neighbor 206.83.43.46
 address-family {
     ipv4-unicast {
         maximum-prefix 1
 description "Peer: E2W Solutions AS394414"
 remote-as 394414
[email protected]# show protocols bgp 951 neighbor 2001
2001:504:9b::1   2001:504:9b::10  2001:504:9b::2   2001:504:9b::30  2001:504:9b::46  2001:504:9b::9
[email protected]# show protocols bgp 951 neighbor 2001:504:9b::46
 address-family {
     ipv6-unicast {
         maximum-prefix 8
 remote-as 394414
The old backend with “peer groups” contains some bugs
https://phabricator.vyos.net/T2845
https://phabricator.vyos.net/T3604
https://phabricator.vyos.net/T3855
And maybe some others
In 1.4 bgp was completely rewritten
Thanks @Viacheslav - really looking forward to 1.4 LTS.
Would a possible workaround be to entirely remove the neighbor, commit, and then add the neighbor back with the desired peer-group?
