The documentation doesnt really seem to be the right thing. How would I clamp TCP MSS for my tun0 adapter on VyOS 1.3.3?
This is an old solution. No need to setup tcp-mss as a policy.
Policy route needs if you want to set mss for inbound packets.
So, it is not old; it just sets TCP-MSS for different directions.
You can dump traffic in one and another option and check in/out packets.
Great, Thanks! Such as wireguard or gre tunnel interface. Which one should we use?
use this blog as reference it will help
