VyOS 1.3 L2TP over IPSec + Firewall, L2TP vpn can not work
Hi Everyone,
I am useing VyOS 1.3 rc6; This is the link of reference manual: L2TP — VyOS 1.3.x (equuleus) documentation
I config a L2TP over IPSec in VyOS works fine, but when I set up the firewall, VPN can not work;
I just observe that all traffic of the vpn is dropped:
What could be the reason for this state ?
Below is my configuration:
vyos@vyos# show interfaces ethernet eth0
 address dhcp
 firewall {
     in {
         name wan
     local {
         name wan-local
 hw-id 00:0c:29:2b:3a:d0
vyos@vyos# show firewall name
 name wan {
     default-action drop
     rule 1 {
         action accept
         state {
             established enable
             related enable
     rule 2 {
         action drop
         state {
             invalid enable
 name wan-local {
     default-action drop
     rule 1 {
         action accept
         state {
             established enable
             related enable
     rule 10 {
         action accept
         destination {
             port 22
         protocol tcp
     rule 40 {
         action accept
         protocol esp
     rule 41 {
         action accept
         destination {
             port 500
         protocol udp
     rule 42 {
         action accept
         destination {
             port 4500
         protocol udp
     rule 43 {
         action accept
         destination {
             port 1701
         ipsec {
             match-ipsec
         protocol udp
vyos@vyos# show vpn
 ipsec {
     ipsec-interfaces {
         interface eth0
     nat-networks {
         allowed-network 0.0.0.0/0 {
     nat-traversal enable
 l2tp {
     remote-access {
         authentication {
             local-users {
                 username user {
                     password user
             mode local
         client-ip-pool {
             start 192.168.33.100
             stop 192.168.33.200
         gateway-address 192.168.33.1
         ipsec-settings {
             authentication {
                 mode pre-shared-secret
                 pre-shared-secret 123456
         name-server 119.29.29.29
         outside-address 192.168.66.108
Hi @storm ,
Your firewall rules look fine
Try changing the default rule to accept to verify that it is a firewall
set firewall name wan-local default-action accept
I don’t see packets in the rule 43
Try to allow all UDP traffic to port 1701
Allow protocol 50,51 (ah, esp)
Hi, Nikolay,
if set default-action accept, everything works fine, but the security of the routing system itself is a big problem. :joy:
1701 is probably encapsulated in 4500
protocol ah shouldn’t be used
Instead of rule 43, try allowing all ipsec decrypted packets.
Or add an extra block or allow rule with logging enabled, to see in log what you’re missing.
“allow all UDP traffic to port 1701”
This config solves the problem;
Thanks!
