Hi All,
I tested MPLS in Version, I find some issues. My network diagram and configuration:-
I cannot ping from vyos13-1 to vyos13-3 and the next-hop address (i think the next-hop address is the opposite router interface ip) are not correct in all routers. Please give me some suggestions
Thanks,
Tom
What IPs specifically are you trying to ping?
edit:
Are you pinging the loopbacks, and properly sourcing from the loopback?
I try to ping 3.3.3.3 from source 1.1.1.1 or 12…0.0.1.
Hi Sinilli,
Could you set the following command?:
set protocols mpls interface 'ethX'
where ethX are the interfaces connected to p/pe routers .
It can work.
set protocols mpls interface ‘ethX’
Thanks.
