Hi there,
I want to disable replay protection on the child, but the conf file is empty in strongswan.d and in other directories, how do I go about changing this? I can do this easily in 1.4
Hi there,
I believe 1.3 still used ipsec.conf instead.
Where is it located?
I found it, just in /etc
Any idea how to persist changes? Seems like it’s generated by a script
Also is there work being done to have the replay_window config available via the vyos config abstraction?
I’d recommend making a feature request on https://vyos.dev
⚓ T5998 replay_window setting under vpn in config - FR
Script:
#!/bin/vbash
cp /config/swanctl.conf /etc/swanctl/swanctl.conf
run restart ipsec
exit
