Vyos version: 1.4.0
Environment: vyos on vmware
Configuration:
[edit system flow-accounting]
vyos@vyos# show
+enable-egress
+interface wg0
+netflow {
+ server 1.2.3.4 {
+ port 4739
+ source-address "10.1.1.1"
+ version 10
Hello, I enabled ipfix on vyos 1.4.0, and around 12 hours after, vyos crashed with kernel panic.
I was averaging around ~40 flows per second, at a 1:1 rate.
Syslog does not show any useful information about the crash. The solution was to reset the VM.
This is the only information I was able to grab, from the vmware console.
Edit: after reading the docs, I see it is recommended to use disable-imt parameter. Why is it not disabled by default?
