I have a a cert and key for domain.com , but its ca is actually a bundle of 3 different certs.
I have done the following
set pki ca 01cert certificate ‘text’
set pki ca 02cert certificate ‘text’
set pki ca 03cert certificate ‘text’
so the 3 certs in the bundles is available as 01cert 02cert and 03cert
I have my regular cert as
set load-balancing reverse-proxy service https ssl certificate domaincert
The load balancer is working with the issue ‘unable to get local issuer certificate’ …
so how do I tell vyos that the cert ‘domaincert’ has 3 ca certs 01cert 02cert and 03cert.
Thanks,
