hook.ua
December 27, 2023, 10:33am
1
Hi there
I’m trying to use recent vyos 1.5 to upgrade year old 1.4 based firewalls
Everything looks fine during automated upgrade but l2tp remote access doesn’t started due to undefined error in accel-ppp service.
Is this bug or feature.
where should I search for problem root?
Thnks
Could you share your config ?
show conf com | match l2tp
hook.ua
December 27, 2023, 1:32pm
3
Sure, please find below
set vpn l2tp remote-access authentication mode 'radius'
set vpn l2tp remote-access authentication mppe 'deny'
set vpn l2tp remote-access authentication radius server 10.1.0.xx key ''
set vpn l2tp remote-access authentication radius server 10.1.0.xx port '1812'
set vpn l2tp remote-access authentication radius source-address '10.1.0.yy'
set vpn l2tp remote-access authentication require 'mschap-v2'
set vpn l2tp remote-access ccp-disable
set vpn l2tp remote-access client-ip-pool def range '10.1.0.tt-10.1.0.pp'
set vpn l2tp remote-access default-pool 'def'
set vpn l2tp remote-access name-server '10.1.0.xx'
set vpn l2tp remote-access outside-address 'external ip'
After initial failed configuration conversion all l2tp comands were entered manually.
Message log has only below information
Dec 27 15:25:10 DISTI-PRO systemd[1]: Failed to start accel-ppp.service - Accel-PPP.
Dec 27 15:25:10 DISTI-PRO kernel: [ 2.548239] fail to initialize ptp_kvm
Dec 27 15:25:10 DISTI-PRO kernel: [ 3.183512] piix4_smbus 0000:00:01.3: SMBus Host Controller not enabled!
Dec 27 15:25:10 DISTI-PRO kernel: [ 3.331439] vbd vbd-5696: 19 xenbus_dev_probe on device/vbd/5696
Dec 27 15:25:53 DISTI-PRO bgpd[1417]: [VCGF0-X62M1][EC 100663301] INTERFACE_STATE: Cannot find IF xfrmi-test-1862 in VRF 0
Dec 27 15:27:24 DISTI-PRO systemd[1]: Failed to start accel-ppp@l2tp.service - Accel-PPP - High performance VPN server application for Linux.
Dec 27 15:27:26 DISTI-PRO systemd[1]: Failed to start accel-ppp@l2tp.service - Accel-PPP - High performance VPN server application for Linux.
Thanks
Hi @hook.ua
This bug was fixed today.
current ← aapostoliuk:T5859-circinus
opened 10:52AM - 27 Dec 23 UTC
## Change Summary
Fixed format of ipv4 pool range from 'x.x.x.x-x.x.x.y' to '… x.x.x.x-y'
## Types of changes
- [x] Bug fix (non-breaking change which fixes an issue)
- [ ] New feature (non-breaking change which adds functionality)
- [ ] Code style update (formatting, renaming)
- [ ] Refactoring (no functional changes)
- [ ] Migration from an old Vyatta component to vyos-1x, please link to related PR inside obsoleted component
- [ ] Other (please describe):
## Related Task(s)
* https://vyos.dev/T5859
## Related PR(s)
## Component(s) name
l2tp, sstp, pptp, ipoe, pppoe
## Proposed changes
Fixed format of ipv4 pool range from 'x.x.x.x-x.x.x.y' to 'x.x.x.x-y'
## How to test
CLI Configuration:
`set vpn pptp remote-access client-ip-pool TEST range '10.0.0.100-10.0.0.102'`
/run/accel-pppd/pptp.conf
Before:
[ip-pool]
10.0.0.100-10.0.0.102,name=TEST
After
[ip-pool]
10.0.0.100-102,name=TEST
## Smoketest result
vyos@vyos:~$ /usr/libexec/vyos/tests/smoke/cli/test_service_ipoe-server.py
test_accel_ipv4_pool (__main__.TestServiceIPoEServer.test_accel_ipv4_pool) ... ok
test_accel_local_authentication (__main__.TestServiceIPoEServer.test_accel_local_authentication) ...
No IPoE interface configured
ok
test_accel_name_servers (__main__.TestServiceIPoEServer.test_accel_name_servers) ... ok
test_accel_next_pool (__main__.TestServiceIPoEServer.test_accel_next_pool) ... ok
test_accel_radius_authentication (__main__.TestServiceIPoEServer.test_accel_radius_authentication) ... ok
Ran 5 tests in 18.508s
OK
vyos@vyos:~$ /usr/libexec/vyos/tests/smoke/cli/test_service_pppoe-server.py
test_accel_ipv4_pool (__main__.TestServicePPPoEServer.test_accel_ipv4_pool)
Test accel-ppp IPv4 pool ... ok
test_accel_local_authentication (__main__.TestServicePPPoEServer.test_accel_local_authentication) ...
User "test" has rate-limit configured for only one direction but both
upload and download must be given!
ok
test_accel_name_servers (__main__.TestServicePPPoEServer.test_accel_name_servers) ... ok
test_accel_next_pool (__main__.TestServicePPPoEServer.test_accel_next_pool)
T5099 required specific order ... ok
test_accel_radius_authentication (__main__.TestServicePPPoEServer.test_accel_radius_authentication) ... ok
test_pppoe_server_authentication_protocols (__main__.TestServicePPPoEServer.test_pppoe_server_authentication_protocols) ... ok
test_pppoe_server_client_ipv6_pool (__main__.TestServicePPPoEServer.test_pppoe_server_client_ipv6_pool) ... ok
test_pppoe_server_ppp_options (__main__.TestServicePPPoEServer.test_pppoe_server_ppp_options) ... ok
test_pppoe_server_shaper (__main__.TestServicePPPoEServer.test_pppoe_server_shaper) ... ok
test_pppoe_server_vlan (__main__.TestServicePPPoEServer.test_pppoe_server_vlan) ... ok
Ran 10 tests in 36.115s
OK
vyos@vyos:~$ /usr/libexec/vyos/tests/smoke/cli/test_vpn_l2tp.py
test_accel_ipv4_pool (__main__.TestVPNL2TPServer.test_accel_ipv4_pool)
test_accel_local_authentication (__main__.TestVPNL2TPServer.test_accel_local_authentication) ... ok
test_accel_name_servers (__main__.TestVPNL2TPServer.test_accel_name_servers) ... ok
test_accel_next_pool (__main__.TestVPNL2TPServer.test_accel_next_pool)
test_accel_radius_authentication (__main__.TestVPNL2TPServer.test_accel_radius_authentication) ... ok
Ran 5 tests in 20.337s
OK
vyos@vyos:~$ /usr/libexec/vyos/tests/smoke/cli/test_vpn_sstp.py
test_accel_ipv4_pool (__main__.TestVPNSSTPServer.test_accel_ipv4_pool)
test_accel_local_authentication (__main__.TestVPNSSTPServer.test_accel_local_authentication) ...
ok
test_accel_name_servers (__main__.TestVPNSSTPServer.test_accel_name_servers) ... ok
test_accel_next_pool (__main__.TestVPNSSTPServer.test_accel_next_pool)
test_accel_radius_authentication (__main__.TestVPNSSTPServer.test_accel_radius_authentication) ... ok
Ran 5 tests in 21.853s
OK
vyos@vyos:~$ /usr/libexec/vyos/tests/smoke/cli/test_vpn_pptp.py
test_accel_ipv4_pool (__main__.TestVPNPPTPServer.test_accel_ipv4_pool)
test_accel_local_authentication (__main__.TestVPNPPTPServer.test_accel_local_authentication) ... ok
test_accel_name_servers (__main__.TestVPNPPTPServer.test_accel_name_servers) ... ok
test_accel_next_pool (__main__.TestVPNPPTPServer.test_accel_next_pool)
test_accel_radius_authentication (__main__.TestVPNPPTPServer.test_accel_radius_authentication) ... ok
Ran 5 tests in 20.351s
OK
## Checklist:
- [x] I have read the [**CONTRIBUTING**](https://github.com/vyos/vyos-1x/blob/current/CONTRIBUTING.md) document
- [x] I have linked this PR to one or more Phabricator Task(s)
- [x] I have run the components [**SMOKETESTS**](https://github.com/vyos/vyos-1x/tree/current/smoketest/scripts/cli) if applicable
- [x] My commit headlines contain a valid Task id
- [ ] My change requires a change to the documentation
- [ ] I have updated the documentation accordingly
hook.ua
December 27, 2023, 2:27pm
5
it’s great to know. Thanks
I just simply need latest nighty build, right? Tomorrow?
Because I’ve used recent today.
Yes. This fix was merged 18 minutes ago. It will be in the next nighty build or you can build and install a package yourself. Build VyOS — VyOS 1.5.x (circinus) documentation
hook.ua
December 27, 2023, 3:13pm
7
thanks, I could wait for a while.
hook.ua
December 29, 2023, 3:36pm
8
Caught the updated version just after 3 hours after publication.
Test shows good result - accel and l2tp VPN + RADIUS works fine.
Thanks
