Hello!
Trying to build latest arm64 build, but I have a problem with the telegraf package:
[2022-01-18 08:40:16] lb chroot_install-packages install
P: Begin installing packages (install pass)…
Reading package lists…
Building dependency tree…
Reading state information…
debconf is already the newest version (1.5.77).
gnupg is already the newest version (2.2.27-2).
gpgv is already the newest version (2.2.27-2).
Some packages could not be installed. This may mean that you have
ntp : Conflicts: time-daemon
systemd-timesyncd : Conflicts: time-daemon
vyos-1x : Depends: telegraf (>= 1.20) but it is not installable
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: An unexpected failure occurred, exiting…
P: Saving caches…
make: *** [Makefile:32: iso] Error 1
