Dear colleagues,
I migrated a router with Vyatta to VyOS 1.1.0, but instability appeared right after the upgrade. The router has a lot of bgp session - around 100 and from time to time without any reason the router become unresponsive for around 15-20 seconds.
Please find below some logs with call traces:
[2652491.189858] Call Trace:
[2652491.189863] [] ? default_idle+0x1b/0x2c
[2652491.189867] [] ? cpu_startup_entry+0x132/0x1a9
[2652491.189871] [] ? start_secondary+0x25e/0x263
[2652491.189873] Code: d8 c3 0f 22 df c3 0f 20 e0 c3 0f 20 e0 c3 0f 22 e7 c3 44 0f 20 c0 c3 44 0f 22 c7 c3 0f 09 c3 9c 58 c3 57 9d c3 fa c3 fb c3 fb f4 f4 c3 8b 07 53 49 89 c9 49 89 d0 8b 0a 0f a2 89 07 89 1e 41
[2652491.189909] NMI backtrace for cpu 15
[2652491.189915] CPU: 15 PID: 0 Comm: swapper/15 Not tainted 3.13.11-1-amd64-vyos #1
[2652491.189929] Hardware name: Supermicro H8DGU/H8DGU, BIOS 2.0a 11/08/2011
[2652491.189941] task: ffff8802168d2a00 ti: ffff8802168e0000 task.ti: ffff8802168e0000
[2652491.189949] RIP: 0010:[] [] native_safe_halt+0x2/0x3
[2652491.189965] RSP: 0018:ffff8802168e1ed0 EFLAGS: 00000246
[2652491.189976] RAX: 0000000000000000 RBX: ffff8802168e0010 RCX: ffff880617cc0000
[2652491.189985] RDX: 0000000000000000 RSI: 000000000000000f RDI: 0000000000000001
[2652491.189992] RBP: ffff8802168e0000 R08: 0000000000000000 R09: ffff8802168e0000
[2652491.189999] R10: 0140000000000000 R11: ffff8802168e0010 R12: ffff8802168e0000
[2652491.190006] R13: ffff8802168e0010 R14: ffff8802168e0010 R15: ffff8802168e0010
[2652491.190014] FS: 00007f303a10b700(0000) GS:ffff880617cc0000(0000) knlGS:0000000000000000
[2652491.190022] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[2652491.190029] CR2: ffffffffff600400 CR3: 000000080e068000 CR4: 00000000000007e0
[2652491.190040] Stack:
[2652491.190046] ffffffff8101650b ffff8802168e0000 ffffffff81083b41 0000000000013080
[2652491.190070] 979237b1cc46d5b6 0000000000000282 00000000300001df 0000000000000000
[2652491.190109] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[2652491.186377] Call Trace:
[2652491.186379]
[2652491.186380] [] ? default_send_IPI_mask_sequence_phys+0x9e/0xc7
[2652491.186387] [] ? arch_trigger_all_cpu_backtrace+0x44/0x6c
[2652491.186391] [] ? rcu_check_callbacks+0x1f8/0x5a0
[2652491.186395] [] ? tick_nohz_handler+0xce/0xce
[2652491.186398] [] ? update_process_times+0x31/0x56
[2652491.186402] [] ? tick_sched_timer+0x74/0x90
[2652491.186405] [] ? __run_hrtimer+0x92/0x11c
[2652491.186409] [] ? hrtimer_interrupt+0xde/0x1ec
[2652491.186413] [] ? read_tsc+0x5/0x16
[2652491.186416] [] ? tick_check_idle+0x43/0x93
[2652491.186420] [] ? smp_apic_timer_interrupt+0x1d/0x2d
[2652491.186424] [] ? apic_timer_interrupt+0x6d/0x80
[2652491.186426]
[2652491.186427] [] ? native_safe_halt+0x2/0x3
[2652491.186433] [] ? default_idle+0x1b/0x2c
[2652491.186437] [] ? cpu_startup_entry+0x132/0x1a9
[2652491.186441] [] ? start_secondary+0x25e/0x263
[2652491.186443] Code: f2 48 89 f0 0f 83 8a 00 00 00 48 89 d1 49 89 d0 48 c1 e9 06 49 83 e0 c0 4c 8d 0c cf 48 89 f7 4c 29 c7 83 e2 3f 74 39 48 83 c8 ff <88> d1 48 d3 e0 49 23 01 48 83 ff 3f 76 3b 48 85 c0 75 4e 49 83
[2652491.186483] NMI backtrace for cpu 1
[2652491.186495] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.13.11-1-amd64-vyos #1
[2652491.186498] Hardware name: Supermicro H8DGU/H8DGU, BIOS 2.0a 11/08/2011
[2652491.186501] task: ffff88021689c600 ti: ffff8802168bc000 task.ti: ffff8802168bc000
[2652491.186504] RIP: 0010:[] [] native_safe_halt+0x2/0x3
[2652491.186511] RSP: 0018:ffff8802168bded0 EFLAGS: 00000246
[2652491.186513] RAX: 0000000000000000 RBX: ffff8802168bc010 RCX: ffff880217c40000
[2652491.186515] RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000001
[2652491.186518] RBP: ffff8802168bc000 R08: 0000000000000000 R09: ffff8802168bc000
[2652491.186520] R10: 0140000000000000 R11: ffff8802168bc010 R12: ffff8802168bc000
[2652491.186523] R13: ffff8802168bc010 R14: ffff8802168bc010 R15: ffff8802168bc010
[2652491.186526] FS: 00007f303a10b700(0000) GS:ffff880217c40000(0000) knlGS:0000000000000000
[2652491.186528] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[2652491.186530] CR2: ffffffffff600400 CR3: 000000041174b000 CR4: 00000000000007e0
[2652491.186532] Stack:
[2652491.186534] ffffffff8101650b ffff8802168bc000 ffffffff81083b41 0000000000013080
[2652491.186538] 2dbacbf22979a2fc 0000000000000282 00000000300001df 0000000000000000
[2652491.186542] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
