I am running on 1.4-rolling-202208010217, I have just met an issue when I trying to delete bgp neighbor by command delete vrf name VRF-DSR203-GLO2 protocols bgp neighbor 10.85.226.197, then commit failed with below errors. Now my VyOS config was unsync with frr.conf, when I try to delete the neighbor again, it still got below error. Is there any way to correct this?
[ vrf name VRF-DSR203-GLO2 protocols bgp ]
https://support.vyos.io/
- Make sure you are running the latest version of VyOS available at:
https://vyos.net/get/
- Consult the community forum to see how to handle this issue:
https://forum.vyos.io
- Join us on Slack where our users exchange help and advice:
https://vyos.slack.com
business policy requires it)
Report time: 2022-08-26 18:46:42
Image version: VyOS 1.4-rolling-202208010217
Release train: sagitta
Built by: autobuild@vyos.net
Built on: Mon 01 Aug 2022 02:17 UTC
Build UUID: 5595cd3f-204c-47e2-a354-c1f304fed6c0
Build commit ID: ffc63f19772a5f
Architecture: x86_64
Boot via: installed image
System type: bare metal
Hardware vendor: Dell Inc.
Hardware model: PowerEdge R630
Hardware S/N: J1HJ9C2
Hardware UUID: 4c4c4544-0031-4810-804a-cac04f394332
File "/usr/libexec/vyos/conf_mode/protocols_bgp.py", line 383, in <module>
apply(c)
File "/usr/libexec/vyos/conf_mode/protocols_bgp.py", line 374, in apply
frr_cfg.commit_configuration(bgp_daemon)
File "/usr/lib/python3/dist-packages/vyos/frr.py", line 480, in comm
it_configuration
raise ConfigurationNotValid(f'Config commit retry counter ({count_max}) exceeded')
vyos.frr.ConfigurationNotValid: Config commit retry counter (5) exceeded
