Vyos BGP configuration using Ansible
I have this BGP configuration setup on Vyos 1.3
vyos@vyos# show protocols bgp
bgp 65535 {
address-family {
ipv4-unicast {
network 172.16.0.0/16 {
ipv6-unicast {
network 2001:db8:1::/48 {
neighbor 192.168.50.233 {
address-family {
ipv4-unicast {
remote-as 65535
I want to implement this same configuration using ansible module.
I have checked BGP module.
https://docs.ansible.com/ansible/latest/collections/vyos/vyos/vyos_bgp_global_module.html
There are parameters for setting up ‘network’, ‘remote-as’, ‘route-reflector’ etc but
I did not see any parameters for ‘address-family’, ‘ipv4-unicast’ and setting up network inside it.
Also I did not see any parameter to setup as-path-list specifying regex.
How should I proceed further? I know I can use jinja file but is there any way I can use BGP modules to setup above BGP configuration?
Hi @qwerty ,
Try using this ansible module to handle ‘address-family’:
https://docs.ansible.com/ansible/latest/collections/vyos/vyos/vyos_bgp_address_family_module.html#ansible-collections-vyos-vyos-vyos-bgp-address-family-module
And you can configure any commands with this module:
https://docs.ansible.com/ansible/latest/collections/vyos/vyos/vyos_config_module.html#ansible-collections-vyos-vyos-vyos-config-module
Hi @Nikolay ,
I am getting this error.
ERROR! couldn’t resolve module/action ‘vyos.vyos.vyos_bgp_global’. This often indicates a misspelling, missing collection, or incorrect module path.
I am using Ansible 2.9 version. Do I need to use ansible 4.0 version to work with BGP modules?
Don’t worry I figured it out.
I installed the required modules using ansible-galaxy and it worked.
Hi @qwerty,
Yes, these modules are part of ansible-galaxy.
The good news is that they work :grinning:
