Vyos container missing ports
problem: 3 ports mapped, only the last port is mapped
version: 1.4-rolling-202308240020
config
set container name adguardhome image 'adguard/adguardhome:v0.107.36'
set container name adguardhome network proxy
set container name adguardhome port dns-tcp destination '53'
set container name adguardhome port dns-tcp protocol 'tcp'
set container name adguardhome port dns-tcp source '53'
set container name adguardhome port dns-udp destination '53'
set container name adguardhome port dns-udp protocol 'udp'
set container name adguardhome port dns-udp source '53'
set container name adguardhome port http destination '80'
set container name adguardhome port http protocol 'tcp'
set container name adguardhome port http source '80'
set container name adguardhome restart 'always'
set container name adguardhome volume config destination '/opt/adguardhome/conf'
set container name adguardhome volume config source '/home/yikyo/container/adguardhome/config'
set container name adguardhome volume data destination '/opt/adguardhome/work'
set container name adguardhome volume data source '/home/yikyo/container/adguardhome/data'
set container network proxy description 'proxy network'
set container network proxy prefix '10.10.10.0/24'
show container
NAMES PORTS …
actual result adguardhome 0.0.0.0:80->80/tcp …
expected result adguardhome 0.0.0.0:53->53/tcp, 0.0.0.0:53->53/udp,0.0.0.0:80->80/tcp, …
Do you have DNS forwarding configured? Because it will already listen on port 53 which will prevent this container from also listening on that port. You will also need net-bind-service to bind to a privileged port so I am confused that it works for port 80.
set container name adguardhome cap-add net-bind-service
I personally struggled a bit with getting containers to listen to privileges ports. What I did instead is that I configured a non-standard DNS port as the listening port for my container, and configured the DNS forwarding to go to that instead and all my DNS clients would consume DNS from VyOS VLAN interface instead.
To see if something else is listening on that port you can use netstat:
sudo netstat -ntulp
My configuration can be seen in another forum post: Encrypt DNS requests to WAN - #2 by jagekurt
I’ve created a PR to fix this issue: container: T5463: Fixes indentation to publish all port nodes by sarthurdev · Pull Request #2171 · vyos/vyos-1x · GitHub
Thanks for reporting the issue.
It’s great that the problem was solved so quickly
thanks
I don’t have DNS forwarding configured,I use adguardhome directly as a dns server
I run this command and nothing happens.
Run this command
sudo netstat -ntulp | grep 53
tcp 0 0 127.0.0.1:2601 0.0.0.0:* LISTEN 853/zebra
udp 0 0 10.10.10.1:53 0.0.0.0:* 3290/aardvark-dns
Are you able to commit without any errors when you use source 53 on both TCP and UDP for the port mapping?
Yes, there are no errors.
But I modified the file /usr/libexec/vyos/conf_mode/container.py according to the PR of sdev
I can’t commit successfully, the config source is port 53
thanks
