Vyos default user remains usable after deleting!
I am setting up one platform with Equuleus 1.3.0 and I have this security issue.
I load my config from file, commit, save. Then I logout the router and login with my own user (not vyos default user), to delete vyos user from config.
I made “delete system login user vyos”, enter, commit, save.
I made “show system login user ?” and I can only see my custom created users, not vyos default user.
Then I logout the router and try to login with vyos/vyos…and it WORKS!!!
I look again at the config and i can’t found vyos user…but it works…
Then I made a system reboot and vyos user didn’t work any more, but I need to reload the system.
vyos@XPi204r# show system login user
Possible completions:
ansible
juan
vyos@XPi204r# exit
exit
vyos@XPi204r:~$ exit
logout
WELCOME TO XPERIENTIA SYSTEMS. UNAUTHORIZED USE OF THIS SYSTEM IS PROHIBITED!
XPi204r login: vyos
Password:
PLEASE, LOGOUT THIS SYSTEM SECURELY!
vyos@XPi204r:~$ configure
ansible
juan
user ansible {
authentication {
encrypted-password ------------------------------------
plaintext-password “”
user juan {
authentication {
From how to remove vyatta user - #2 by cgb
Since /etc/passwd is modified on boot from the saved config, I found that deleting the ‘user XX’ snippet from /config/config.boot, and then rebooting, successfully removed the user from config & from /etc/passwd etc.
I would consider this a bug but not sure if there is legacy reasons why a user is never truly deleted. I’ll email vyos-users for feedback from the devs.
This seems this is still true; that the /etc/passwd file is modified on boot. :point_down:
@thomasjsn, not the case anymore.
@jvilafe are you sure that you did not see any warning or error messages during the commit, while you removed the “vyos” user? During the normal commit, a user deleted from config is removed from the system immediately.
Can you provide a step-by-step procedure on how to reproduce this in a fresh install?
@zsdc, yes, I’m sure. This is a common procedure that I did every on fresh install.
  1. Install from buil iso
  2. reload system
  3. log with vyos/vyos
  4. configure
  5. load config launching ASCII file from console
  6. commit & save
  7. exit from router
  8. login again with my own user
  9. configure
  10. delete vyos user from config.
  11. commit & save
  12. exit from router and try to log again with vyos/vyos.
In this case, I can login with vyos/vyos after vyos user deleting, so:
  1. configure
  2. show system login user
    *** vyos user didn’t show in the output list***
I think that vyos deleted user was really deleted from config, but remains active in the running or memory util system reboot.
I will try again from fresh 1.3.0 install and let you know
This would be great. Maybe I am missing something specific to your config in my test case:
[ successful login with vyos/vyos ]
conf
set system login user newuser authentication plaintext-password 'newpass'
commit
save
exit
exit
[ successful login with newuser/newpass ]
conf
commit
save
exit
exit
[ failed login with vyos/vyos ]
mmmh
I can’t reproduce it on fresh install.
I have screenshoot facing vyos login without vyos user in the config. I will send to you in separate email, because this screenshoot has my real usernames and hostname…
thankyou
Thanks! Received it.
Theoretically, this could happen only if the userdel program or base Python libraries do not work. At least now, I have no other ideas.
If you will be able to reproduce this, please tell us.
