I’m building a PoC for VyOS hub routers in GNS3. All spoke routers are Cisco, with a VyOS hub behind a firewall. I can get the tunnel to come up on one spoke router, OSPF adjacency forms, traffic passes, etc. The second I try to bring up a second spoke, the first one drops and the second one establishes connection. I’m using vyOS 1.4 rolling 202212310809. Am I missing something in my VyOS config? The spokes work fine with a Cisco Hub. I’m wondering if it has something to do with NAT-T, but I can’t find a nat-traversal command on this image?
HUB config:
set interfaces ethernet eth0 address ‘10.100.1.3/26’
set interfaces tunnel tun0 address ‘172.16.21.254/24’
set interfaces tunnel encapsulation ‘gre’
set interfaces tunnel ip adjust-mss ‘1360’
set interfaces tunnel mtu ‘1400’
set interfaces tunnel tun0 multicast ‘enable’
set interfaces tunnel tun0 parameters ip key ‘1’
set interfaces tunnel tun0 source-address ‘0.0.0.0’
set protocols static route 0.0.0.0/0 next-hop 10.100.1.62
set protocols nhrp tunnel tun0 cisco-authentication ‘passkey’
set protocols nhrp tunnel tun0 holding-time ‘600’
set protocols nhrp tunnel tun0 multicast ‘dynamic’
set protocols nhrp tunnel tun0 ‘redirect’
set protocols nhrp tunnel tun0 ‘shortcut’
set vpn ipsec esp-group ESP-HUB lifetime ‘3600’
set vpn ipsec esp-group ESP-HUB mode ‘transport’
set vpn ipsec esp-group ESP-HUB pfs ‘disable’
set vpn ipsec esp-group ESP-HUB proposal 1 encryption ‘aes128’
set vpn ipsec esp-group ESP-HUB proposal 1 hash ‘sha1’
set vpn ipsec ike-group IKE-HUB key-exchange ‘ikev1’
set vpn ipsec ike-group IKE-HUB lifetime ‘86400’
set vpn ipsec ike-group IKE-HUB mode ‘aggressive’
set vpn ipsec ike-group IKE-HUB proposal 1 dh-group ‘5’
set vpn ipsec interface ‘eth0’
set vpn ipsec profile NHRPVPN authentication mode ‘pre-shared-secret’
set vpn ipsec profile NHRPVPN authentication pre-shared-secret ‘PSK’
set vpn ipsec profile NHRPVPN bind tunnel ‘tun0’
set vpn ipsec profile NHRPVPN esp-group ‘ESP-HUB’
set vpn ipsec profile NHRPVPN ike-group ‘IKE-HUB’
Spoke Config (Works perfectly with Cisco Hub, or single router spoke to VyOS Hub):
crypto isakmp policy 100
encryption aes
group 5
crypto isakmp key PSK address 0.0.0.0
crypto ipsec transform-set xfrm esp-aes esp-sha-hmac
mode transport
crypto ipsec profile SPOKE
set transform-set xfrm
int tun0
ip addr 172.16.21.x 255.255.255.0
ip mtu 1400
ip nhrp authentication passkey
ip nhrp map 172.16.21.254 <*public IP of HUB>
ip nhrp map multicast <*public IP of HUB>
ip nhrp network-id 1
ip nhrp holdtime 600
ip nhrp nhs 172.16.21.254
ip tcp adjust-mss 1360
tunnel source fa0/0
tunnel mode gre multipoint
tunnel key 1
tunnel protection ipsec profile SPOKE
